Jim Lewis
- First Name
- Jim
- Jan 10, 2023
- San Antonio, TX
- Honda Accord 2017; 2023 Lariat ER
- Occupation
- Retired
Today when I went to load some stuff into my truck bed, I noticed a plastic strip at the back inside top edge of my tailgate is popping out at one attachment point (see picture below). I tried pushing the bulge back in with my hand, even stomping on it with my foot. No luck. Does anyone know the proper way to reattach this trim? Is there a special tool required? Would the loose trim be a warranty issue that the dealer should fix?
As to what's causing the problem, my top theory is that if I put my Bak Mx4 tonneau cover down with the tailgate up, perhaps the bottom back edge of the tonneau cover is chopping the trim off the tailgate at the point of the problem. I've rolled a ~100 lb object on a dolly up a ramp onto the bed, but I don't think the dolly wheels transitioning in the slight gap between the top of the ramp and the inside top of the tailgate caused the strip to come loose. Another theory is that the intense Texas summer heat in some random asphalt parking lot caused the strip to differentially expand compared to the tailgate and pop out.
I have doubts whether all the fancy plastic tailgate "work surface" trim is built to handle all the loading/unloading of stuff I plan for my truck down the line. The miscreant bulge doesn't give me faith that the rest of the trim in the truck will be able to go the distance.
