Blue Cruise adaptive cruise….
RustyMitchell
James
Anthem Arizona
New owner here…….2300 miles…….. has anyone experienced the blue cruise spontaneously going from the set cruise (65-70) to 80 or even 90 miles an hour with no driver input? Did it at low speed as well. Set at 25, jumped spontaneously to 40……..
Double check your setting for reading the speed limit signs. Beyond that...no clue.
Yes, many. You have speed sign recognition turned on in settings. It will see a sign (or get the data from a database). There is also a setting that tells it how many miles over the speed limit it sees you want to be. So, if it sees a 70mph sign, and you have it set to 10 over, it will accelerate to 80mph.
This is of course exactly as it is supposed to perform. You need to turn off the settings, and should review ALL your settings to understand them.
Can't recommend this enough. Take an hour and just look through every setting in every menu. Well worth the time spent.
Lytning
Georgia
Agreed. Also, read the PDF Owners manual 5 or 10 pages at a time. You will learn a lot about your truck, as well as know where to find information when you need an immediate answer.
Mal106
Mal
SW VA
2025 Lightning Flash
Retired Pilot
Blue cruise should not work above 80.
