tommolog
- First Name
- Tom
- Jan 16, 2022
- New Jersey
- Website
- www.youtube.com
- 2022 F-150 Lightning Lariat, 2023 Rivian R1S, 2024 Chevrolet Equinox EV
- Occupation
- Journalist
With the Lightning's relatively flat charging curve up to 80%, it would be better to charge up to that, rather than multiple short stops which can be a better strategy with some other EVs.The problem with this scenario is that it is highly unlikely the DCFC will be available and working at exactly the right interval. for 15min stops. The more times you have to stop and the more times you're plugging in, starting the unit, etc. the more risk something will go wrong(I'm looking at you EA).
In addition you lose any time advantage you may have when you add in time to exit the highway, drive to the DCFC(hopefully close to the exit), exit vehicle, start charge sequence, drive back to highway, etc. That can easily add 5-10min onto every stop....which means if you're doing that 13x vs 8x (or 6x) its not worth it to stop for a 15min charge.
If you're stopping anyway..sure plug it in and get a splash a electrons while you stretch, go pee, grab a burger, etc. but I'm failing to see where it works in practice stopping for all 15min. With a flat curve to 80%..if you've got a good charging session going..just leave it until the charging curve drops.
@tommolog -- this would be a good idea for one of Kyle's "vegas" challenges..... multiple short stops vs. long deep charges. On EVs with a flat curve(aka e-tron, Lightning, etc) I'm thinking deep charge is faster in the real world
