- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
just an observation on my current camping trip: some comparisons between some brand-name fast chargers along the way...
this was a good way to start...
WHERE you stop to charge matters, for many reasons:
1) Speed
2) Cost
3) Logistics and 'space'
4) Number of units per location
A) Chargepoint, Spence Chevrolet, Thomasville, GA... brand new Fast Charger advertised at 62.5kwh speed, and $6 'per hour' fee - a single unit.
1) SPEED: I arrived with about 40% SOC, and the unit ramped up to ~52 for most of the charge, but no higher, no matter what CP advertises when the truck reached 80%, the speed immediately dropped to ~41kwh, which is a design by Ford, itself.
2) COST: $6 per hour is eye-catching, and it is probably one of the lowest cost units I've seen since ownership, BUT, the amount of time you need to charge, versus the max speed of the unit at only 52kwh, like in this situation... you may be there a while. Total of 12cents p/kwh, though : )
3) LOCATION: this is at a chevy dealership, on the right side, and while a relative easy charger to get to, it is, unfortunately, in a fairly restricted parking 'area', built out nicely, but not with much thought to large EVs, and certainly NOT for those of us towing. Other dealer cars are parked right up next to the only two parking spaces in front of the unit, leaving little room for maneuvering. While I arrived very late at night, after the dealership had been closed for hours, I still had to pull past the unit, around the back of the building, and carefully 'turn around' the whole truck and camper train in order to get back to the unit on the correct 'charge port' side, where the charge cord would then reach. If this were the case during a day when the dealer is open, I would doubt this might even be doable.
*) I APPRECIATE greatly this dealer providing a fast charging option in an area of south Georgia where there is relatively few options at all. They have made a big investment, and I'm sure their BOLT and coming EV owners will appreciate it, and travelers as well. Thanks. I am not complaining!
I wish I saw FORD dealers with these same fast chargers.
B) ELECTRIFY America, N Tallahassee large shopping area parking lot, next to Tesla Superchargers - 4 units, with one on the perpendicular. 350kwh units.
1) SPEED: YES! These are fast, and give my truck the max - ~152 to ~132 variable during the majority of the short charging time, starting from 65% SOC, until the dreaded Ford 80% 'slow down' mandatory restriction - ~41kwh, just like with the Chargepoint. FAST, though.
2) COST: a fixed 48cents per kwh. No matter the speed, you pay by the KWH - which seems fair....BUT, the same fee compared to the low $6 per hour CP unit is many times higher. Most folks might not argue since the speed gets you there much quicker... TAX is also added into the total of 50cents p/kwh.
3) LOCATION: fairly good location right off the main road, with lots of parking area nearby, spaces between EA and Tesla, and even room for me to pull in perpendicular easily to the #4 far left unit. LATE AT NIGHT is the easy time to charge. This might not be so convenient at 1pm in the afternoon. With these units being in a rather 'open' large parking lot, there are plenty of places for those waiting to 'stage' their vehicles.
*) These units were recently upgraded to the 350kwh speed units, but #1 'perpendicular' unit was not operational. That seems to be common for EA.
C) EVgo, S Atlanta(below the airport), in a vacant parking area, not well lit, not well visited, and, unfortunately, not somewhere I might stop after dark. FAST units, and 'dual' units that can power TWO evs at once from the same 'unit' - via two different charge cords. While this is 3 units, it is for up to 6 vehicles at once. Tesla adapter, and Chademo included.
1) SPEED: yes, good speeds. Take your pick for 150kwh, 100kwh, or 50. My 'sharing' with another vehicle, a Bolt EUV, resulted in slower speeds than if I was there
by myself, but still usable. 62kwh during most of the charging curve, while the Bolt used 50kwh. This was still less than the advertised 150kwh speed, but there
may be some reason why 'sharing' creates a lower output, versus a single vehicle's max output.
2) COST: total of 31cents p/kwh.
3) LOCATION: as stated, not great - room to maneuver, and ability to pull up next to the charge perpendicular, if needed, but nothing close by when it comes to a restroom or other option - a very long walk, if so, and probably not the area you might want to do that, unfortunately.
*) I appreciate this fast charger option south of the metro, before you drive thru the city - but, the area makes it a toss-up as to whether you'd want your son or daughter to go there alone. When we talk about being 'held hostage' to the charge port LOCK while charging, making a 'quick' escape impossible, you'll start to understand my concern.
No photos for this one...
D) SHELL Recharge/GreenLots(?) Wakulla Florida area, in a hotel parking lot - two 'fast' chargers, although two different 'brands', and 4 Level 2 options, all hosted from Duke Energy:
1)SPEED: not great, but since there is basically NO OTHER FAST CHARGER option anywhere near this 'coastal' area of Florida's 'bend', you take what you can get. 41kwh is not terrible, but for the whole charge curve, it requires some patience. I did not try the 'second' fast charger, with a tag that branded it as a 'efaces', operated by GreenLots, although it did not necessarily give me the impression it was operational, but who knows. The left unit looked more 'recent', and while it took me a while to get my card to go thru, having to 'tap' it instead of swiping, it worked. I've read reviews on plugshare that these units are VERY hit-and-miss, and no one had charged here for some time. Also, interestingly, these DC units show up NOWHERE on my FordPassApp search, but only as "6 of 7 available" and then only lists the 4 Level 2 chargers on the app. Strange.
These don't show up even on GOOGLE MAP search, only on plugshare.
2)COST: so far, I couldn't tell you. There is nothing on the unit or the screens mentioning a price, and when I swiped my card to activate several times, it asked me if I wanted a 'receipt', which I said yes. When the unit would not activate with a swipe several tries, I then noticed that you could 'tap'. The tap, though, is on a separate 'pad' next to the 'swipe' area, and not clearly defined as 'where' to tap. I also had then said 'no' for a receipt, so I never received one at the completion of charging, and have YET, 12 hours later, to receive a hit on my card, which texts me immediately for any charges, and NOTHING shows on the card website to allude to any charge from this DC Fast Charger. Could it be free?? Maybe, but when the charge shows up, maybe in several days, I'll find out how 'much' it cost me.
3)LOCATION: well, right off the highway, yes, but if you are towing, it might be not so friendly a spot. The two DC chargers are all the way to the right side of the parking area, and not even seen from the roadway. I had to park, turning hard right, with my camper still in the entry way, but out of the lane enough to let anyone pass. That also created a nervous situation when back out, since the truck and camper were at 75degrees, but I barely made it. For simple small EVs, these are fine, but today's truck EVs, and even future larger SUV EVs, especially if towing, will find this an appreciated option, even if a little difficult to maneuver thru.
Google Maps.... nothing.
Plug share: thank you.
FordPassApp: no help.
no pricing data, or on-screen receipt when complete...
When we travel, and consider fast charging, it seems to be the wild west out there right now, not only cost-versus-cost, which swings WILDLY between charge options, but just the shear consideration to make, especially while towing, of 'where' your fast charger is located, and whether you can easily access it.
Maybe, in the future, we'll have dedicated 'gas station' type 7-Eleven EV Charging Stores where you can rest assured you have the cost, entry and exit, maneuverability, speed, reliability, amenities, restrooms, and location options, in a known 'brand' setting.
1) Speed
2) Cost
