Replacement rear (driver side) light
matt.sillz
Matt
ATL
Ford F150 Lightning, Mach-e
Marketing/Advertising
Hello,
Does anyone know a good place to get affordable light replacements for a 2023 Lariat? Someone ran into my driver side light and condensation is happening inside the fixture. Ford wants 2700 to replace it. My nephew just left Ford as a tech and can do the replacement - just need the part.
Many thanks!
Ford F-150 Lightning Replacement rear (driver side) light Screenshot 2023-10-06 at 8.22.10 AM
vagabond7846
NJ
I have the same issue. A crack lead to water damage, which fried the BLIS sensor inside the taillight, and Ford wants $3200 to replace the entire taillight and sensor. You may have the same problem if water has pooled in the bottom. My truck is throwing BLIS error messages and cross-traffic sensors disabled.
The sensor itself is cheap, but I do not yet know how to use FORSCAN to reprogram the sensor. If your nephew is able to do a write-up on how to use FORSCAN to reprogram a new light/sensor, that would be very valuable to me (and hopefully others in this community)
ddimit
Sacramento, CA, United States
2015 Tesla model S 2023 F150 Lightning Lairat
Manager
It's insane the amount of money they want for these, and it is not limited to the lightning. Other F150s are having issues with water incursion. def something to keep and eye on for any issues
matt.sillz
Matt
ATL
Thank's ya'll. I'll ask if he can program FORSCANi for sure and let you all know how - if he can.
Just remember there are two versions of the tail lights (one for Pro/XLT and one for Lariat Platinum). Some eBay sellers are not doing a good job showing which one. The seller @Blochead21 linked to is very good and shows the difference. I have bought from that seller and recommend.
Also, if your BLIS module is undamaged you can easily transfer it over to the new light - just three T20 screws. Then no need to reprogram.
LightningBug
Rich
South Florida
2023 Lightning Lariat ER
Bug Guy
As mentioned, there are 2 different versions. This one on this eBay listing is for a Pro or XLT.
Pretty sure that's the Lariat version that OP needs. It has the trapezoidal backup lamp.
Blochead21
PA
Black 22 XLT 311pkg
It’s clearly shown in the listing.
Ford F-150 Lightning Replacement rear (driver side) light IMG_5985
Ford F-150 Lightning Replacement rear (driver side) light IMG_5986
Tfarrell73
Tim
New Lenox, Illinois
23 F150 Lightning Lariat ER
Try a local bodyshop. Had water in a fog lamp while ago. Dealer wanted $1000 to replace. Body shop did it for $200 with OEM part
LightningBug
Rich
South Florida
Bug Guy
Second thought, I think you’re right. Good catch.
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
FWIW, I just went through this replacement this afternoon. The BLIS sensor is a bit tricky. three screws remove the housing, but the wiring isn't long enough to fully disengage from the lamp housing, so you need at least two, maybe three, steady hands. One holds the housing, other removes the two torx screws that secure the strap that secures the sensor to the lamps housing.
Ford F-150 Lightning Replacement rear (driver side) light 20250503_141140
Ford F-150 Lightning Replacement rear (driver side) light 20250503_141151
Ford F-150 Lightning Replacement rear (driver side) light 20250503_142705
Ford F-150 Lightning Replacement rear (driver side) light 20250503_142710
