Anyone seen a plowing mod?
WhipSticks
Stephen
Maine
2023 F150 Lightning
Scientist
The absence of an accessible frontal plow attachment point gave me pause when I placed my order. But now I am seeing the occasional aftermarket front bumper, and it made me wonder if anyone has managed to attach a plow blade to the lightning. Truck doing truck things...
Yellow Buddy
Smart Ass
From what I can see, it would need to remove some shrouding below as well. I ended up going with a backblade pull plow.
Truck doesn't possess the capability to plow, unless you're using a fixed blade with no hydraulics / electric connections.
sotek2345
Engineering Manager
I have a DIY built wooden back blade (push) that covers what I need for my driveway.
Electric Messiah
Davis
Massachusetts
F150 Lightning Lariat ER
I have a Snowsport fixed blade that I have had attached to a Tacoma truck— and which has worked well on a long driveway—would like to put on front of Lightning, if feasible.
GarageMahal
JT
Data Wrangler
I have been researching how best to do this since I first heard about the Lighting. No luck so far but do think the aftermarket will eventually come out with a front receiver hitch at which point it gets a lot more possible.
I believe the lightning has about 50 amps of 12v accessory power so it will probably require adding an additional battery or two to buffer the draw. It takes under an hour to do all my plowing so I think I will be fine with additional batteries even if I never connect into the truck side power.
This is basically a research project for me as I will likely never actually do it... My requirement is to be able to revert to stock appearance quickly and easily.
For us southerners, I would love to see a picture of a wooden DIY back blade, whatever that means :)
sotek2345
Engineering Manager
Here you go, this is my old truck though.
Ford F-150 Lightning Anyone seen a plowing mod? IMG_20200105_163140
Ford F-150 Lightning Anyone seen a plowing mod? IMG_20200105_163122
MickeyAO
Mickey
San Antonio Tx
This is why I retired from the Air Force in South Texas and did not return to a previous duty station in Nebraska where I met my first wife ;)
BBG523
Chicago
2023 Lightning Platinum, 2021 Model Y, Bolt EV
Here you Go....https://www.youtube.com/watch?v=HTsSumpOCe8
Riptonite
Vermont
2022 F150 Lightning, 2023 Rivian R1S
7'6" BOSS HTX on a '22. Works well with full hydraulics despite no mods to electrical capacity. I added a SuperDuty six switch overhead console to enable plow relays and directly control the plow high and low beams. I did not mess with the factory lights, just augment the headlights and do not use plow turn signals.
This week my wife and I plowed out 8-12" across two storms from a half mile driveway/access, seven offshoot driveways and two small parking lots. Also cleared part of the local roads: 4-6" at 40 mph.
Truck does truck things, but we must charge up all the way every night since this is a standard battery.
Ford F-150 Lightning Anyone seen a plowing mod? 20251123_153312
Ford F-150 Lightning Anyone seen a plowing mod? 20251204_115520
Ford F-150 Lightning Anyone seen a plowing mod? 20251123_135122
