Anyone ever use an undercarriage pressure washer on your Lightning?
I can't use a pressure washer due to me having a well, however the local car wash has a "undercarriage wash" and I take advantage of that as much as possible.
We have a well, why are you limited on water use?
There is little reason to do a high pressure wash of the underside of the truck. I wouldn't do it. A simple hose nozzle should be enough to wash off anything.
lakeguy55
New Hampshire
2023 Lightning Lariat, 2011 F-150, 98 Expedition
I was wondering the same. We are on a well and use our pressure washer all the time.
I took the battery cover off of mine for the first time yesterday. I too live on a dirt road and was surprised at how much dust was all over everything in there.
SmoothJ
New Jersey
2022 F150 Lightning
I am not 100% sure... I know the pump was replaced in ~2019 and the original HO (homeowner) said he was told to not use a pressure washer. That was in ~2021 when I picked up this house.
I should maybe ask the company that put in the pump, but based on the invoice it appeared to be a Franklin 10gpm 1/2hp 230v 3 wire pump... which even using my 4200PSI pressure washer I think its only ~4 GPM.
Lightning Rod
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
I used the undercarriage washer on my truck and my girlfriend's car and I must say, it works very well!
I sprayed each vehicle undercarriage very thoroughly, for several minutes. The sprayer tips are perfect for my 3400 psi sprayer and I think will be perfect for removing salt, calcium chloride and dirt that compromise the frame in these harsh Northeast Ohio winters!
Ford F-150 Lightning Anyone ever use an undercarriage pressure washer on your Lightning? Screenshot_20231108_215009_Dolphin
Lightning Rod
Lightning Rod
North Coast
I've used this product about once a week for the past month and a half, and this unit works very well. I don't worry about salt promoting rust on the undercarriage anymore. :cool:
Jim Lewis
San Antonio, TX
Lightning Rod
Lightning Rod
North Coast
If an undercarriage pressure washer can hit the bumper sensors, you might want to reconsider. The owner's manual specifically advises not to pressure wash cameras and sensors.
https://www.f150lightningforum.com/forum/threads/passenger-side-lariat-‘emblem-door’-blew-off.17905/post-359961
I appreciate this info. I read that on page 448 of the manual but it doesn't go into detail about it. It says to use warm or cold water and a soft cloth to clean cameras and sensors but it doesn't illustrate how to go about cleaning or where exactly these seniors and cameras are.
The spray nozzles are not really that much pressure. I will research more on how to clean these sensors by hand and find out exactly where they are, but I think I will continue to spray the undercarriage of my truck. I will just take extra precautions in certain locations under there as I spray wash.
Thanks.
Jim Lewis
San Antonio, TX
I bought a spray bottle at a Walmart SuperCenter for $1.18 (cleaing aisle in grocery section)
Ford F-150 Lightning Anyone ever use an undercarriage pressure washer on your Lightning? 1704824449029
and a roll of 75 tear-off microfiber towels for $14.97 (auto department):
Ford F-150 Lightning Anyone ever use an undercarriage pressure washer on your Lightning? 1704824614971
can be washed and reused >50x.
I put distilled water (the bottled water section of your grocery store) in the spray bottle. I vigorously mist the cameras and sensors one at a time, starting with the cleanest and working towards the dirtiest. After spraying a camera or sensor vigorously for several spray squeezes, I just gently blot (not wipe) the water away, removing lots of dirt on the dirtiest cameras or sensors.
On a Lariat ER, there are 5 exterior cameras (frunk hood under Ford emblem, side view mirrors, top rear of cab, top center of tail gate). There six sensors on the front bumper and six sensors on the rear bumper. Below is a picture of the 3 sensors on the left half of my front bumper.
Ford F-150 Lightning Anyone ever use an undercarriage pressure washer on your Lightning? IMG_0706_Edtd_Rdcd
mefly2
j
W Montana
23 Lariat ER / KO2s max tow ; 22 F350, 23 C8 Vette
Retired CSc/Math teacher. LEO
References to pages in the owners manual ... is there a printed manual?
Jim Lewis
San Antonio, TX
p.448. A link was given in my first post in this thread: https://www.f150lightningforum.com/forum/threads/passenger-side-lariat-‘emblem-door’-blew-off.17905/post-359961
There is no printed owner's manual that I know of. The manual is ~662 pages long. There's an electronic version in your truck, a web version, and you can download or open a PDF from the web.
An advantage of the electronic version is that rather than relying on a TOC or index, you can search it. I no longer use Adobe Acrobat (too expensive) but one used to be able to do complex Boolean searches on PDF material, e.g., "pressure NEAR sensor," and define what NEAR meant, e.g., how many words separation max.
mefly2
j
W Montana
Must be blind, lots of info but I don't see a link to a manual ... just the thread.
derm
Lance
Chesapeake VA
2023F-150 Lighting Lariat. 2003 Ultra Classic
I've been through multiple high pressure undercarriage washes without any issues
Same here. OBX driving often on the beaches. Local brushless car was has thus feature. No issues.
Lightning Rod
Lightning Rod
North Coast
Here in Ohio, there is a lot of salt used on the roads in the winter. Many car washes here have the Chassis Bath sprayer for the undercarriage. What I don't like is, these places here uses a system that filters and reuses the same old water over and over to wash the cars. I'd rather use my own equipment and my own water so I know the job is done right and without reused water.
