Lightning Rod
- Nov 27, 2022
- The North Coast
- 2023 Ford Lightning Lariat ER
- Occupation
- CNC PROGRAMMER/MACHINIST
I live in Northeast Ohio and this state uses plenty of salt and calcium chloride for snow and ice removal. I want to be able to fully rinse the undercarriage at home (when the outside temperature is above 38 degrees F) to help remove some of that salt and grime sticking to the bottom of the truck. I'm hoping that this will not hurt the truck or any wiring under there.
I just bought this one from Amazon and I will use it with my Westinghouse 3400 psi pressure washer.
Tool Daily Dual-Function Undercarriage Cleaner with Swivel Wheel, Surface Cleaner for Pressure Washer, Underbody Car Wash Water Broom, 16 Inch, 4000 PSI https://a.co/d/51NIG37
Do you guys think that this is safe for our EV trucks?
Thanks.
Thanks.
