Best Dash mounting solution (by Rubigrid) !!
AZT9
Peoria, AZ
Hey All,
I have been waiting for this company to finish developing this dash mount for a while. Just got it in and installed. It’s great! All metal system using AMPS mounting protocol and ball mounts. Everything is carbon or metal! It can be used to solidly mount everything from phones to gps to dash cams to radar. If you’re needing a dash system. This is the one!!
Ford F-150 Lightning Best Dash mounting solution (by Rubigrid) !! IMG_6294
Ford F-150 Lightning Best Dash mounting solution (by Rubigrid) !! IMG_6296
Ford F-150 Lightning Best Dash mounting solution (by Rubigrid) !! IMG_6295
luebri
Neenah, WI
That things a beast! Wow.
I found a simple suction to MagSafe solution that works very well for me.
Ford F-150 Lightning Best Dash mounting solution (by Rubigrid) !! 1700259185516
Minh
Minh
NJ
Here is mine, Amazon sell same one but for some reason the clip on didn’t stay. This one I ordered from China since it was cheap and took the chance on it. Haven’t fall off and it’s wireless charging. Does not obstruct anything and if need be the ventilator can be tilt up to hit the phone incase it get overheated from charging.
Ford F-150 Lightning Best Dash mounting solution (by Rubigrid) !! IMG_9174
AZT9
AZT9
Peoria, AZ
That would have been great. Unfortunately due to the larger screen and the blue cruise sensor. My mounting options were limited.
RTanton
Russell
Mission Viejo
2022 Ford Lightning Platinum
Hey All,
Tom, where dis you find this? I have been searching for a mount for my dashcam that does not block the front window.
petemill
Pete
Santa Barbara, California
'22 ER Lariat +PRB +Unleashed, '11 ford escape v6
Software
That USB port is pretty low power - you're not getting the full apple magsafe charging speed
AZT9
AZT9
Peoria, AZ
@RTanton
They have mounts for almost anything.
luebri
Neenah, WI
Yea, the charging rate isn't all that important to me. It's primary serving as a mount. I keep a USB-C to lightning cable in the truck in case I need a faster charge.
eRockBoon
Erik
Kansas
F150 Lightning Pro (extended range)
Do you have a link to share?
HaroldCal
Harold
Las Vegas, NV
The installation appears to involve double stick tape and self tappers... Not ideal.
