Flash Monroney Sticker
intensifi
San Mateo, CA
Mach E
Flash Window sticker for review.
Cars dot com sent me an alert. I followed it to the dealer web site to share with the assembled brain trust!
Ray R
Lightning Flash, Model Y Performance
Yep. My local dealer has four of them listed on their website.
I don’t think they’ll show anything about the heat pump since all trim levels get them.
131KWH EXT BAT-SINGLE CHGR
I believe this means 40 amp max AC charging? Is that a Flash thing or a Lightning thing.
I'd be interested to see how many people regularly use more than 40 amps. My main charger is limited to 32 amps due to wiring constraints. Occasionally, it won't hit my target charge level in my 10 hour time of use window. It's never mattered for me but I could see how a lower charging rate could hamper someone with a long commute.
Dual charges eliminated for 2024 on all trims. Limit is 48A, not 40.
The window sticker as posted has a few inconsistencies but it would seem that the flash only has 1 charger. The charge time listed on the sticker is higher than a dual charger.
The co2 rating (tailpipe only) is shown as 9. That's not correct, there is no tailpipe, it should be 10.
Can confirm that dealer advertising lines for 2024 Lariat say : "level 2 charge speed 11.5kw". That is 48amps. That is what I use and have found it to be the sweet spot.
I wonder if they will use the dual charger setup for fleet as they would be the most likely customer for fastest 240v charging?
I think Ford wants to sell DC chargers to fleets. Eliminating the dual charger helps force the issue.
Dual charger is available as fleet option for Flash (Edit: and Pro):
Ford F-150 Lightning Flash Monroney Sticker 1705859678396
mefly2
j
W Montana
23 Lariat ER / KO2s max tow ; 22 F350, 23 C8 Vette
Retired CSc/Math teacher. LEO
Yes, likely Ford did a survey - resulting in the charging speed ...
