2025 Flash = 123kw battery, 2024 Flash = 131kw battery, same range?
user-name-required
T
BC
2024 F150 Lightning Flash, 2023 ID4 pro S
Minor one here, not sure if its been discussed.
But, the 2025 flash trim is showing as a 123kw usable battery and up to 515kms range (~320-322 miles), and the 2024 I bought has a 131kwh usable battery and the same posted range.
Did they actually get 9.4% more efficient and I am missing something here, or?
HOTAS
‘24 Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
Not the same range
2024 is rated at 320 miles
2025 is rated at 300 miles
a 9.4ish% difference
quite a shame imho
Reactions: chl
ClevelandBeemer
2025 F150 Lightning Flash 131kWh
Nope as EPA range is 300 miles. Keep in mind the smaller pack saves several hundred pounds and the motors produce slightly less power.
That said, the build date of the 2025 Flash is important. I own a 2025 Flash with the 131kWh useable battery.
Lots of discussion. See this thread for instance.
https://www.f150lightningforum.com/forum/threads/2025-flash-battery-size-determination-psa.27990/
