Power deployed steps vs. fixed steps
willk66
Reno, Nevada
Ioniq 5, Ford Maverick
Do the power deployed steps extend lower and further out than the fixed steps? I am talking about the PWR-DEPLOYABLE BDS W/BLK ACCNT option (not 3rd party). Just wondering as it would make it easier for my elderly in-laws.
PreservedSwine
Fort Myers
2023 Lightning
I don’t have the OEM retractable steps, (not an option on the PRO) but briefly saw them in action while shopping for my lighting. They extend much lower, and slightly further out than fixed.
I had AMP retractable steps installed, for the exact same reason. I believe the AMP steps go a little lower and further out than OEM, and may be better suited for trucks that have been lifted. Or in my case, legs that refuse to ?
My wife is struggling at times to step up into the cabin, I've got to get serious about testing the OEM models before she suggests selling the Lightning ..... that ain't happening.
Adventureboy
They make a HUGE difference. They are definitely lower and further out than the fixed boards and provide a solid step instead of just a toe. Both my father and mother are elderly and handicapped. The retractable boards make it much easier for them to get in. I've had them on my 2018 ICE and now on my Lightning and will order them on my next.
You've sold me ..... I'm going to check in with the dealer to order them and install on this summer's tire rotation visit and clear up the LVB CSP alert for which I've already replaced the module.
The factory power steps are a little lower than the fixed steps when deployed, and stick out further.
It's not plug and play to install the factory steps after the fact. You'd be better off to go aftermarket.
PACSMAN
Fred
Massachusetts
F150
I've had both on my Lightnings and I agree the power running boards stick out a little farther and lower than the fixed ones. I'd order them again.
Adventureboy
The only warning is that you need to do fall maintenance to keep them operating smoothly since you live in the salt zone. A little spray of Fluid Film (or equivalent) in the right places keeps things sealed and lubricated. No issue on my 2023 since I now do the maintenance, but my 2018 needed a bit of "loosening up" after about 3 years. I now do the fall maintenance religiously since it only takes 5 minutes.
I added simple-to-install fixed running boards soon after my truck arrived: haven't regretted one moment, and certainly DON'T need any 'moving' running boards - the fixed variety are perfect and don't impede on any use of the truck. They are just there when you need them.
Adventureboy
I believe Ford has the manufacturing rights from the AMP Research design. I'd go that route if aftermarket is easier.
djwildstar
Guy
Atlanta, GA
2023 Lightning Lariat ER, 2023 Mach-E GTPE
Information Security
Yes -- same here: my wife was complaining that it is difficult to get in and out, and that she feels like her footing isn't secure, particuarulay when getting out of the cab.
I went with the AMP PowerSteps, and it has made a world of difference for her. I don't know about the OEM retractable steps, but the PowerSteps swing out lower and farther than the fixed running boards. They are also set up so that you can get your full foot firmly on the step, so now she feels more secure climbing in and out of the cab.
AMP produced the factory power steps for the 2015 to 2020 model years. 2021+ are made by Magna.
I had the AMP steps on my 2018, and the factory Magna steps on my 2021. The AMP steps are lower, and stick out farther, when deployed. They are also quieter in and out of the cab.
eRock77
Eric
Akron, OH
2023 F150L Pro--1995 Exploder--1929 A Super Coupe
My 2023 Pro has a grey two-pole oval shaped power plug down underneath that looks like it would plug into power running boards. Do the Pro trucks come set up for that or are those just for zone lights? Am I going to run into some kind of a Forscan nightmare making power boards work?
