Gloss Black powdercoat OEM Lariat wheels looks fantastic!
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Ford F-150 Lightning Gloss Black powdercoat OEM Lariat wheels looks fantastic! IMG_1053
Ford F-150 Lightning Gloss Black powdercoat OEM Lariat wheels looks fantastic! IMG_1052
Gloss Black powdercoated OEM Lariat wheels look fantastic!
I hated the stock grey of the OEM Lariat wheels. Gloss black powdercoat is tougher and looks great in pictures, even better in person. Just had them mounted to brand new Michelin Defender LTX Platinum LT265/60R20s. *Very* quiet and smooth tire!
Now I have to decide whether to sell this new set as a package or keep them on the truck!
(PS I love how different the Azure Grey Metallic looks under different light. These pic were taken minutes of each other)
csukoh78
Nope
SE USA
I always had Michelin Defenders on my Escalade - so the ride feels a lot smoother/quieter than the tires that came on the new truck? Yes to that grey color - reflects bluish.
Much more so. Even my wife noticed. The stock tires were ok at first but after 20k miles they are relatively loud, almost as loud as my Tesla tires.
Nice looking wheels.
Keep us updated on any efficiency hits you take with those tires. I'm sure a lot of us, me included, will need new tires coming up.
csukoh78
Nope
SE USA
Oh I doubt very much that there will be an efficiency hit, if anything they'll be more efficient. They are very quiet and very comfortable. They are low rolling resistance and design for heavy duty light trucks in the weight range of the lightning., EV qualified
csukoh78
Nope
SE USA
I was thinking of dipping my Lariat wheels gloss black. After seeing yours I might have to do it soon.
I have zero regrets, believe it or not it actually *accentuates* the curves and flat areas of the wheel and makes it more dynamic looking. That color gray just made it look like a bleh disk and I hated at the moment I saw it. "Brake dust" should never be the color of a wheel from the factory.
If you choose to make your grill gloss black, the best way to do that is to just have it vinyl wrapped. It lasts forever, is removable, and matches the wheels perfectly. It was also cheap, 160 bucks.
I now have a lariat ER that has a gloss black grill and gloss black wheels and I'm telling man it looks gorgeous. Got three compliments just going to UPS today.
02Reaper
GA
2022 Lightning XLT ER
On another note....How does that Icon suspension setup ride?
csukoh78
Nope
SE USA
shockingly good! It does not ride as a semi – lowered truck at all. The slop and floating feeling is completely gone. It handles bumps very well and is absolutely flat around corners.
Although the suspension has less travel, the computer/app adjust to road conditions very quickly (thousand times a second?) The rear suspension is very very close to the bump stop and I did not even lower it the full 4 inches or so. I may end up lifting it another half inch or so. Icon recommends 1 inch of thread showing.
The replacement bump stop they have are very good. If you do happen to bottom out, there's no shock or jolt because the suspension handles it so well. overall it rides tighter, smoother with less cushion feel. It really shines around curves though, no more worrying body lean.
mb0220
Matt
2022 Lariat ER
I always liked the look of the Lariat wheels except for the color. What you did is exactly what the doctor ordered. Damn I might just sell my after market wheels and do what you did. Super jealous of the Azure Grey as well.
Is there a reason you went with 265 width tires instead of 275 (same as stock)?
And did you lower the rear? Looks like much less rake than usual. I need to copy this...
csukoh78
Nope
SE USA
Check out how good it looks with black lug nuts.
Agree, I think the wheels look great and set the Lightning apart. Hated the color but gloss black is perfect.
Shame they discontinued AGM!
the truck is lowered 2" in front and 3" in rear using the ICON full kit with camber adjusters. It's great. $$$$ though.
Ford F-150 Lightning Gloss Black powdercoat OEM Lariat wheels looks fantastic! IMG_1123
csukoh78
Nope
SE USA
The reason for the tires is because I really wanted this model, they're very quiet and efficient and have really high reviews. It's the latest heavy duty light truck tire that's also EV qualified. They didn't have the exact stock size so I could go smaller or bigger and I chose to go smaller. Since I was lowering the truck I didn't necessarily want a bunch of meat in the wheel well. There's no rubbing.
02Reaper
GA
I've dropped mine a couple of different ways so far, eibach springs...stock springs with lowering struts...It just doesn't ride as good as stock in any of the ways I have tried. The sweet spot seems to be lowering the back by about 1"-1.5" because any lower and your in bumpstop territory either on the LCA's or on the strut itself. There's just not a whole lot of travel back there for much anything. The Icon set is not for me, but I'm gonna try one more thing before I give up to drop the back down a little bit.
csukoh78
Nope
SE USA
The icon set makes fantastic use of the travel you do have with rapidly modulated struts and progression springs. It's definitely more firm but not jarring in the slightest, it's shockingly good and you can change the settings via the app.
02Reaper
GA
I like the Idea of them, but some of the reviews I have seen put their customer service on the low end. Frequent rebuilds, and you have to take them off and send them off to Icon for that. People have reported the lack of communication from Icon when there is an issue or its time for a rebuild. It's just not something I want to have to go through. I want something more standard where I can just pop off what I have and replace it without much issue. Like I said, I like the idea and I'm not knocking you in any way for your route, but its just not for me.
Peddyr
Peter
New Hampshire
2022 Ford Lightning Lariat SR
Cyber
Wheels look sexy as hell. If you don't mind me asking, what did the powdercoatng set you back?
