On board air compressor mod
dww
San Antonio, TX
F150L, Tesla 3P, YP
Has anyone done an onboard air compressor? I have used a viair 88p in the past and am considering mounting one beside the battery and adding a switch/air nipple to the battery access plate. Does the DC-DC charger for the 12v work when the truck is not on? I would assume yes, but thought I read somewhere that it didn’t. The other idea would be to add an AC (small tank, modded to fit) air compressor to the back where the mufflers go in the ICE truck. There is a ton of room there. You could add the air nipple where the blank is in the bumper. Not sure if I would add a switch or just leave the plug loose. I also have a Ryobi battery compressor, but it just doesn’t have the volume. Other ideas? The tan bag is the Viair hoses and all.
Ford F-150 Lightning On board air compressor mod IMG_4065
Ford F-150 Lightning On board air compressor mod IMG_4064
In general, I figured I would just put mine in the bed if I think I'll need it and plug it in to use. Interesting ideas to mount one though. Going to follow this thread.
invertedspear
AZ, USA
lightningcalcs.pages.dev
I would worry about mounting a pressurized air tank under the truck. I've had lot's of mufflers and even a gas tank take punctures due to road debris in the past. If I had enough constant need for an air compressor that I was considering mounting one, the bed or the frunk would be the only places I would consider. PPOB would negate the need to wire anything directly to the battery IMO.
Texas Dan
Daniel
I have a small 120V tankless air compressor that I keep under the rear seat. I also keep an extension cord in the frunk since the cord on the air compressor is pretty short.
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
I did a similar mod last summer. Pancake compressor in the bed of the truck, bungee'd to the boxlink connector.
EigenSolver
Colorado
2014 Subaru, 2023 F150 Lightning Lariat ER
Reactions: dww
queuewho
Western PA
22 F150 Lightning Lariat SR
Thats great for emergency tire fills, or for after airing down your tires for offroad... but for someone who wants to use a bunch of power tools a compressor with a tank is needed.
