Possible to create a standalone 30A shop power/breaker box that has an extension cord or pigtail to run off the Pro Power in the bed?
Danface
Dan
Central Mass
2023 Lightning XLT
I have one these I was going to use with the truck for the house backup but going with a lockout on the main panel. It should allow for keeping the existing feed and adding circuits from the truck
https://www.homedepot.com/p/Relianc...Circuit-Transfer-Switch-Kit-3006HDK/202213700
If will do the trick, let me know.
There are a few comprehensive threads on using ProPower for home backup containing the info you need. This thread is about a standalone power solution, not backup.
Danface
Dan
Central Mass
2023 Lightning XLT
Only if the existing 15 amp circuit is removed, yes?
