Squeaking sound 2022 Lightning Lariat ER
watson123
Los Angeles
2022 Lightning Lariat ER, Antimatter Blue; Tesla Y
Attorney
Here is a video/audio:
22K miles, just bought her. It has Method wheels with Falken tires, 3" lift. Squeaks quite a bit, this is probably the loudest it gets. Intermittent. I'm guessing this is not the issue addressed by TSB 22 2395. I don't think it's dry bushings. My guess is it's coming from the wheel(s).
Anyone experience this? thanks.
ryun
Earth
Your video is listed as private so nobody here can likely view it.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
watson123
watson123
Los Angeles
Attorney
I published the video so it should be visible. Will send VIN to Ford, thanks.
3121
2022 F150 Lightning Lariat SR Mannequin
You checked the lug nut torque? 150 ft lb
watson123
watson123
Los Angeles
Attorney
No, have not done anything except spray the bushings. Thanks for your suggestion.
3121
my factory wheels were only torqued to 115-125 and made some clicking sounds. I torqued them to spec and went away.
stickyfingers
Sam
Toronto
Sorry to revive this. I am running into the same issue - did your squeak go away? What was the fix if you don't mind me asking. TIA.
