Has anyone installed a homelink rear view mirror?
Andrewbens
Modesto
Lightning
Mechanic
Lightning XLT visors aren’t lighted so I felt doing the mirror was going to be easier.
installed mine today. Thanks for the recommendation and showing everyone this great mod.
WildBlue
Somewhere
2024 F150 Lightning Flash
Would you mind showing up a step by step, by removing your trim and showing the hookup?
Is that trim you used (the one with the sunglass compartment, etc.) able to be separated from the headliner so you can cut the opening in the plastic? Or did you cut the opening in-situ?
Were you able to find some wires in that area that were powered on only when the truck is turned on?
