Volume control failure
JoshuaF
Joshua
F150L2024
F150 Lightning Flash
Professor
I just got my truck back from the dealer who was addressing a non-functioning volume control knob. It would not adjust the volume through the sound system when using any source (e.g. FM radio, Android auto, etc.). The knob would allow fan speed adjustments.
The technician replaced the amplifier and reprogrammed some settings.
Here are some of the codes in the repair order - if anyone can translate them, I'm curious about what they are.
"Confirm concern no sound from all speakers. Scan vehicle with scan tool DTC ACM UO238:00. WSM 415-00 Perform PPT AO. AO1Y AO2Y AO3N AO4N AO5Y AO6Y AO7Y Replace DSP. Order DSP 1978 Form. R&R DSP Program to Vehicle Perform Quick Test to Verify Repair."
"Replacement of the Amplifier"
MrLoganRoss
Logan
Seattle Washington
He the same issue in my ‘24 when I first got it. I don’t recall whether the replaced the ACM or it was a loose plug plus some settings.
Scorpio3d
SS/IBA car wash owner
Well, I know what the last sentence is “repair and replace DSP(digital signal processor?)”then they probably programmed it and tested to verify that it was working and solved the problem.
I think the first part is probably the error codes, but I am not sure
Workshop manual procedure 415-00
Perform pinpoint test, then several steps to the test to determine issues, some were YES and some were NO
JoshuaF
JoshuaF
Joshua
F150L2024
Professor
Thanks for the translations!
