Is there a way to make all four windows roll down with your key fob?
danchristy
Dan
Melbourne FL
F-150 Lighting
Audio Video Lighting Engineer
Is there a way to get your windows to roll down buy holding down the lock button from you key fob like the ICE F-150
mrau
23 Lariat⚡ER
Yes it’s called Global open and Global close windows. It can be enabled through Forscan. Once enabled it can be turned on through the settings on the truck middle screen.
It only works on the front windows, not the rear.
danchristy
danchristy
Dan
Melbourne FL
F-150 Lighting
Thank you
invertedspear
AZ, USA
lightningcalcs.pages.dev
I know there are other threads on this, but it still blows my mind that Ford missed this being available out of the box when it’s on the MME and ICE F150s. It seems like they went out of their way to muck this up on the lightning.
I believe no F-150 does all 4 windows, because the door control on the rear doors isn't capable of Global Windows.
My guess is beacause the rear windows are not equipped with the anti-pinch safety. This is to keep a hand or finger from getting chopped off. The fronts do have that feature.
csukoh78
Nope
SE USA
2023 Ford Lightning Lariat ER
Ford has never enabled the back windows due to child safety protection
You can definitely do the front windows through FORSCAN, it's actually pretty fun to do and then once you go down that rabbit hole there's lots of things you can do
csukoh78
Nope
SE USA
csukoh78
Nope
SE USA
csukoh78
Nope
SE USA
RaspPiDude
Ontario, Canada
2024 Flash (ER), Oxford White
Software Development, Automotive Industry
I can open the windows on my 24 Flash with a double press of the Fob's unlock button, but I can't find a way to close them again. Is it possible to enable closing too?
mrau
23 Lariat⚡ER
If Global Windows is active on your truck, then you should have a menu setting to turn them on/off.
Ford F-150 Lightning Is there a way to make all four windows roll down with your key fob? IMG_3041
RaspPiDude
Ontario, Canada
Oh fascinating! I only have the Remote Open option...!
danchristy
danchristy
Dan
Melbourne FL
F-150 Lighting
What OBD scan tool “brand & Model” should I get it for the Ford F150 lightning 2023 to use with Forscan?
danchristy
danchristy
Dan
Melbourne FL
F-150 Lighting
