Should I buy Fleet 2024 Pro ER or 2024 Flash?
Lightningwaiter
British Columbia
Lightning Lariat ER
Construction
I would go with the flash, the added feature are worth it. I do love the big screen on my truck.
eRockBoon
Erik
Kansas
F150 Lightning Pro (extended range)
I’d be surprised if the flash really is about the same price. It’s MSRP is like 10k over the fleet ER pro
danchristy
Dan
Melbourne FL
F-150 Lighting
Audio Video Lighting Engineer
Hi All,
I could use your input to help deciding between these 3 options. I have to say I'm attracted to the Pro because I prefer knobs over a touch screen for heating/cooling, etc. I will tow building materials over one season but then would probably not have much of a need for towing over the long term. The main features I need are the ER battery and Pro power. Not sure if I'd benefit from having a dual on board charger, but is that nicer to have than the options in number 2 below? Are the prices listed good or should I try to negotiate more? The prices include taxes and fees and take into consideration any rebates, discounts and the EV tax credit.
1. Fleet 2024 Pro ER for $58k out the door
  • Dual on board charger
  • pro power onboard 9.6 kw
  • Max trailer tow package
2. Fleet 2024 Pro ER for $59k out the door
  • Single charger
  • Tow Technology package
  • Pro power onboard 9.6 kw
  • Max Trailer tow package
  • mobile power cord
  • backup alarm system
3. 2024 Flash for about the same price, still waiting on final numbers.
Flash I bought a lariat, wishing it was the flash
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Well, I just happen to be the person that purchased a pro in May 24 and upgraded to a Flash in September.
Both needed to have the tow package and pro power. Both have bed liner, tailgate
Step.
The only practical non advantage of the dual charge pro is the ability to charge from driver or passenger side. Still wish the pro would have had it standard as it had dual charge doors, until you figured out all show and no go. Big mistake in my opinion. Like they designed it that way and needed to cut corners for price.
Flash er battery , more horsepower. Blue cruise, with adaptive cruise control.
Truthfully I do like the smaller screen of the pro, but that’s about it. The flash is the way to go. Especially if you get a 72k flash for the price you’re describing.
Rick
The faux door on the right has NEVER had a charging port, the DUAL refer to the onboard charge controllers in early ER's vs MY24+
Ragman
If the prices are the same the Flash (big screen and all) is the better buy - that said any Flash that cheap is likely missing the 9.6 Propower which can be a deal breaker - as another poster mentioned the MSRP gap is $10k.
Gov’t rebates also play into it, for us a Pro gets $9k vs Flash at $5k so gap gets even bigger.
strahanjen
Jennifer
2024 Ford 150 Lightning Flash
I just got the paperwork for the Flash. I checked the window sticker and confirmed that it has the pro power 9.6. They are offering $60k out the door including all taxes and fees, zero down and 75 months financing at 0% APR. Sounds like I should go for it?
RickKeen
Rick
F150L SR Pro
sw engineering manager,
IMHO, you will NEVER need 80 amp charging - spending money on an option you don't need..
Max Tow / Pro Power is good to have if you tow or need the electric power..
Tow tech used to be required to get the brake controller. Not sure that is still the case. You will want the brake controller if you tow..
Everything else in my book is driver preference.
Ragman
$60 with zero looks okay, best we can get fleet wise on an ER PRO is $74 cda / $52 USD cash. They have a Flash that’s been sitting for $72 cda / $51 usd.
The zero percent is worth about $7,500.
For us the Flash MSRP puts it outside rebate range where Pro gets $9k off above. If they both qualified I’d be buying the Flash.
On single vs dual, there are days I’d like more than 9kw however it hasn’t been enough to bother getting FCSP installed. I believe the single can still do 11.5kw? Just wire in a 48 amp (60 circuit) and you should be happy.
BennyTheBeaver
Also on the Pro, the Tow Tech Package includes the 360° cameras. Those are a big deal to alot of owners.
Lucky Larry
Calgary, AB, Canada
23 Lightning Platinum, 25 Mach-E, 17 RX 350
I think the Flash is the way to go as it seems to be the best deal. dual chargers are not really necessary as you will be able to charge from 20 to 80% in about 9 hrs, using a 240 volt 40 amp charger. You should also be able to drive 30 miles per day to and from work and only have to charge once ever 5-6 days.
Good luck with your decision.
Ricks Lightning
Rick
Los Angeles
Plumbing Contractor
Why did they waste all that money installing a faux charge door if they never planned on putting in an option to either charge 2x faster or the ability to charge from either side.
From an astectic point of view, who cares if it matches. Have you ever seen dual gas flaps that didn't have dual gas tanks?
I think Ford had plans for dual access points and the cost was a deal breaker.
Rick
Ford Motor Company
Official Ford Account
F-150 Lightning
Looks like you're getting more truck for the money with option 1. The flash is only a single charger and Pro-Power is an option.
We think you’d look great behind the wheel of either one, Jennifer. We'd love to set you up with a test drive at your nearest dealer to help make your decision. If you're interested, please send us a DM and we'll provide more information.
mrau
23 Lariat⚡ER
The VIN for the 2024 are coded different than 2022 and 2023.
For 2023 the 8th digit is the battery size. L = Standard Range, V = Extended Range.
Here is code chart for 2022/2023 VINs.
Ford F-150 Lightning Should I buy Fleet 2024 Pro ER or 2024 Flash? Screenshot 2024-11-20 at 2.01.17 PM
