Supercharger Avg Power
Just did back to back 1000 mile trips over the last weekend, here are the specs for tesla chargers (ABRP used for planning).
Average speed=124.7kw
Average kwh=67.97
Average time=33.8 minutes
Average cost=38 cents per kwh
Min/max speed=67/139.2 kw
Min/max kwh=41.5/88
Min/max time=18/47 minute
Min/max cost=$0.36/$0.43
This was the 10 tesla stops, which was 90% of the charging. Trip was across Indiana, Illinois, Wisconsin, and Minnesota (and then back).
LightningShow
MA
'22 Lariat ER
Product Development
I just hit a supercharger close to me to juice up a little before heading up to the ski hill. I pulled in at 40% and got to 60% in 10 minutes for an average of 174kW with peak rate at 188kW. That was by far the best charging session I’ve had. It didn’t drop below 150 for the entire 10 minutes but it was tailing off and would’ve been below 150 shortly after that if I had kept charging.
I had a poor charge in Scottsdale. I definitely did not get the full rate.
Ford F-150 Lightning Supercharger Avg Power 1000006743
I have had good luck elsewhere, so hoping that's a one off.
LightningShow
MA
'22 Lariat ER
Product Development
Is there something different about Superchargers? I've never seen over 167kW on any EA station and I've used many of the 350kW stations (350A and 500A). Why is the SC able to get to almost 190kW? Better cooling? More overhead on the amperage output? There has to be something different about it. 20+kW is a huge difference.
PJnc284
Garner, NC
You should get the same on an EA 350 v a Supercharger due the 500amp boost. Max will obviously depend on current SOC, battery temp, DCFC derating, etc.
SpaceEVDriver
Arizona
The average power I get from a SC is the same as the average power I get from most other DCFCs.
From a recent road trip:
LocationBrandMax SoC %Total kWhTime on charger (minutes)EA Average PowerT Average Power
Kingman, AZT833619114
Needles, CAT867739118
Barstow, CAEA805122139
Mojave, CAT685122139
Kettleman City, CAT825424135
Sacramento, CAEA805926136
Red Bluff, CAT815223136
Yreka, CAEA818241120
Sutherlin, ORT878945119
Portland, ORT85463286
Vancouver, WAEA90302962
Grants Pass, OREA846831132
Redding, CAT92393763
Sacramento, CAT829443131
Kettleman City, CAEA826931134
Ford F-150 Lightning Supercharger Avg Power Screenshot 2025-01-02 at 12.52.58 PM
LightningShow
MA
'22 Lariat ER
Product Development
Ratings and reality are always different. I've never heard of anyone getting over 180kW on an EA charger with the Lightning. Early on there were many, many people reporting the 500A units were topping out around 165-170, maybe low 170s. I've seen it myself on several different stations over the years. The conditions and beginning SoC were definitely optimized in this session but going 20kW over anything I've ever seen before is not likely simply due to charging conditions.
LightningShow
MA
'22 Lariat ER
Product Development
Kingman, AZT0.833619114
Needles, CAT0.867739118
Barstow, CAEA0.85122139
Mojave, CAT0.685122139
Kettleman City, CAT0.825424135
Sacramento, CAEA0.85926136
Red Bluff, CAT0.815223136
Yreka, CAEA0.818241120
Sutherlin, ORT0.878945119
Portland, ORT0.85463286
Vancouver, WAEA0.9302962
Grants Pass, OREA0.846831132
Redding, CAT0.92393763
Sacramento, CAT0.829443131
Kettleman City, CAEA0.826931134
Do you record the peak charge rate?
SpaceEVDriver
Arizona
Very rarely. It's not something that's easily extracted from the FordPass app and I've been having issues with the EA app not giving me my data. I don't know if the T app includes it. Finally, I only sometimes remember to turn on CarScanner.
I don't trust my own eyewitness accounting since I rarely stay at the charger after confirming that the charge has started. My "feeling" of what the peaks are is similar for both. I think it's important to distinguish between "peak" and "spike." A peak should last at least a minute or two to be considered valid. A spike lasts less than a minute and may be a spurious data point for all the good it does for charging the vehicle.
To me the peak is a meaningless number unless I'm only charging for 5 to 10 minutes, and I've only once done that (out of hundreds of DCFCs). I have a record of charging at a T charger for 9 minutes. In those 9 minutes the charger added 25 kWh for a 167 kW average. There was a very short spike to about 170 kW. We unplugged at 49% SoC, so this was in the sweet spot range of highest charge rates.
PJnc284
Garner, NC
If you have ABRP and a bluetooth dongle, you can record the charging curve and download it. Would be nice if it had battery temp and voltage. Believe it was in the 30's this day with no preconditioning as I stopped by the supercharger to kill time.
Ford F-150 Lightning Supercharger Avg Power 1735850544312-at
Webbo85
Marc
Glenmoore, PA
2023 F150 Lightning Lariat ER, 2023 Mach-e, 2002 Jeep Wrangler
Mech Engineer
I've hit 188kW and 178kW max on a newer EA charger in Kingston NY. It lasted a few minutes at most. Still took 28 minutes to go from 49% to 85%, tanking down to 60ish kW at 80%, so still followed the charge curve. Warm battery and a cold day!
Ford F-150 Lightning Supercharger Avg Power EA Max
150Flash
2024 Ford F150 Lightning Flash
EA station charger screen picture after approximately 7 minutes of charging with battery initial state of charge at 18%.
Ford F-150 Lightning Supercharger Avg Power IMG_1350
LightningShow
MA
'22 Lariat ER
Product Development
I'm curious if we get an improved charge curve at some point. I don't recall anyone topping 175kW when I was following this closely.
EDIT: This is from @tommolog original charign test report. He never saw over 170kW even when starting the charge at multiple different SoC. 40% and 50% had the best peak rates.
https://insideevs.com/news/615115/ford-f150-lightning-charging-analysis/
EDIT #2: Here's a more recent thread showing a 195kW charging rate on an EA station.
https://www.f150lightningforum.com/forum/threads/195kw-charging-speed.19647/
LightningShow
MA
'22 Lariat ER
Product Development
Now I feel like we have to have a competition for the first verified 200kW charge rate. ?
LightningShow
MA
'22 Lariat ER
Product Development
@tommolog has verified that Ford rolled out an OTA in October that increased max fast charging rate. That certainly explains the recent change in fast charging I've been seeing.
