What is this and how hard is it to repair/replace?
UglyXLT
2023 XLT
Noticed just now. It’s like some wood/cardboard installed on the backside of the cab.
Ford F-150 Lightning What is this and how hard is it to repair/replace? IMG_2011
Ford F-150 Lightning What is this and how hard is it to repair/replace? IMG_2009
Smartass answer: it's some wood or cardboard installed on the backside of the cab.
Uniformed answer: sound deadening material? If it needs to be replaced - which isn't obvious, to me at least - the bed needs to come off.
The Weatherman
Dean
South Central KY
Are you outside your 3/36k? If not dealer warranty. If so, I would check with a trusted body shop.
UglyXLT
2023 XLT
It’s a 2023 with 26k miles so I’ll be taking it in next week for sure. Just hate that the truck could be in the shop for god knows how long for a piece of cardboard trim. And why would a company install something like that on a vehicle that’s always out in the elements anyways?
The Weatherman
Dean
South Central KY
Well not doubt for cost. It will be interesting to see what the dealer has to say about and to see what it actually made from. Wonder if it’s common to both the Lightning and the ICE F150’s?
There are foam pads glued to the back of the cab for sound deadening. Yours are coming loose. In order to fix it, they will have to pull the bed.
UglyXLT
2023 XLT
damn, seems kinda excessive but it is what it is I guess.
I'm out of 3/36k warranty and have one coming loose. I'm not going to worry about mine, but you should get yours fixed.
Excessive is the foam pads they glued under the 2021 ICE trucks. On the crew cab model, the foam pads under the floor would come loose. They would hang down and drag on the driveshaft. You wouldn't think that would be a severe problem, but it was. There was a huge safety recall over it. When the foam contacted the aluminum driveshaft for an extended period of time, it would score the metal. There was a few failures, and after inspections, many driveshafts needed replacing.
They now install that foam pad inside the cab, under the carpet.
htobin
Howard
Ovalo TX
F150 Lightning 2023 Lariat
Retired surgeon & jet aircraft pilot, Active rancher
Why not just calk it.
Wendy
Puget Sound
1967 Saab 96 (dead), Silverado (squished), 2023 F150 Lariat ER
Weatherman, I'm just looking at your picture ... the lady who did the Silverado vs. Lightning review said she couldn't put her Kayak in the Ford. Looks like you have proven her wrong!
The Weatherman
Dean
South Central KY
This is a 12’6” boat. I also have and carry a 15’ long touring boat as well. The bed extender is a requirement for the longer boat, but would not have been necessary for this boat.
Ford F-150 Lightning What is this and how hard is it to repair/replace? 1736265947041-ws
