24 Flash ER - Underhood Fuses Loose
Kansan
Wayne
2024 Flash
Civil Engineer
Checked my underhood fuse box today. Every fuse was only partially seated. My 23 Lariat 5.0 came with the same situation.
Now I’m wondering what else I should check for.
B177y
Oly Pen, WA
2024 Pro ER Max Tow
Were you having any issues that lead you to check the fuses?
Whammy Bar
The interior fuse panel would be a logical next check.
Kansan
Wayne
2024 Flash
Civil Engineer
I’ve been noticing module communication related DTC codes. They’re not lighting any indicators on the dash. Thinking about it and I remembered the issue with my 23 5.0 and wondered if I might have a loose fuse.
Kansan
Wayne
2024 Flash
Civil Engineer
I checked the interior fuses. Those were all fully seated.
I did need to add coolant once - level was at the bottom of the reservoir. I’m guessing minor air bubbles getting worked out.
If it was a gasser I’d check the rear diff - many of those come a half inch low.
I haven’t looked into this at all - is there a reasonable way to check the fluid level in the drive motors?
