First Trip/Tesla Adapter Use
Rkgensir
Ralph
Delmar, NY
Ford Lightning XLT Extended Range
We went to a Tesla Fast Charger down in Enfield, CT. I had to park sideways to get to the shot cord station. I connected the adapter and plugged in. I looked at my Ford App and saw a disconnect button. I thought that I had messed up. Nope. I was charging. Just by plugging in... Period. GREAT experience.
PLUG-N-CHARGE... yes, it works perfectly. It should be this way at ALL charging locations....
no screen to 'try' to view...
no screen to have to 'touch'
nothing but Plugging IN
simple
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
I got my adapter the other day and did a trial charging session at a Tesla supercharger. Initial plug in gave me an orange ring of lights. Unplugged (after hitting the unlock button) and plugged back in. Zip, started charging. Hit up to 187 kw, with max listed at the station of 250 kw.
Billing through my Blue Oval account. Worked like a charm.
My charger looks different than others I have seen posted. Perhaps a new batch? I labeled it so as to be sure I am using the correct adapter for the correct charger.
Ford F-150 Lightning First Trip/Tesla Adapter Use IMG_1127
And a question for the community. I noticed all the Teslas parked charging with drivers inside and they were surfing the internet on their screens. Can I have the truck on when charging? All prior times I have used DCFC I have gone in to the restaurant or store while charging, so never tried having the truck on while charging.
WaterboyNorCal
Erik
NorCal
2023 Ford Lightning XLT SR
Nunya business ;)
Me too. Typically in ‘accessory mode’ but there is no impact either way on fast charging.
WaterboyNorCal
Erik
NorCal
Nunya business ;)
yep- you have one that is made by Lectron rather than Tesla. Both versions work great- the Lectron is slightly bigger and heavier and has a different locking mechanism. I have both (bought the Lectron for a long road trip through Nevada and Idaho) and received my Ford adapter (made by Tesla) a few months later.
Nomoregas
Scott
Toronto
2022 Ford Lightning
how do you pay for the tesla access? I hear people talk about blue oval where is that on the app store?
Joe.....Montana
Joe
Montana
2023 Lightning
Blue Oval Charging is through your FordPass App. If you have Plug N Charge enabled it will immediately start charging and bill your credit card that is on the account. In my particular neck of the woods purchasing a one month Tesla membership pays for itself in one charge session, so I have to disconnect the plug and charge and initiate charge through Tesla app.
Nomoregas
Scott
Toronto
2022 Ford Lightning
thanks Joe, I have never used the ford app to charge so will look into setting that up for tesla access
Rkgensir
Rkgensir
Ralph
Delmar, NY
Accessory mode? Where is that and BTW, how do I turn on "one pedal." I'd like to try it. TIA, Ralph
bryce
Bryce
when you turn off the plug and charge, do you just disable it with the toggle in the app? Or do you have to change settings in the truck? Would seem easy enough to do so if/when you need to use the Tesla charger. Would be good to do on a road trip, and then restore function after.
It would be nice if the Blue Oval gave you the option to buy the Tesla membership. One can only dream.
Rkgensir
Rkgensir
Ralph
Delmar, NY
Also, are there extention cords for the Tesla stations available? I took up a couple of spaces...
Joe.....Montana
Joe
Montana
2023 Lightning
I toggle the plug and charge off/on within the Ford app. Energy-> Access & Permissions -> Plug & Charge
Rkgensir
Rkgensir
Ralph
Delmar, NY
You get a discount using Tesla App?
potato
BC, Canada
2023 F150 Lightning XLT ER
There is a monthly subscription you can sign up for. If you are charging more than one or two full charges in a month then it's probably worth it. The catch is, if you just plug in, Plug & Charge will not give you the subscription rates. So you need to activate the charger with the Tesla app **before** plugging in.
It is not necessary to disable Plug & Charge, in theory, if you activate the charger with the Tesla app first. But if anything goes wrong with the Tesla activation, P&C may take over and you might not get the subscription discount. I think this is the reason some say you should disable Plug & Charge. But many people charge regularly using the subscription without disabling P&C, just by always activating the charger with the Tesla app first.
