Driver window misbehaving
KennyB123
Ken
Detroit, MI
Very strange behavior yesterday that continued today. I rolled the window down to order fast food. When I used the auto up feature, it went to the top and then auto lowered 2/3rds of the way down.
I can only manage to get it to stay at the top if I feather it with the half press to the near top. If I half press to the top, it will go down 2/3rds again.
I'm guessing this is a service call?
Zed
Chuck
2022 Lightning Platinum Rapid Red
I had this behavior last summer. I had to reset the one-touch close for both windows (both fronts, but not acting up at the same time) but the issue returned. I sprayed some silicone lube into the window channels at the front and rear of the windows and haven't had the problem since. ??
I probably just jinxed myself...
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
This isnt unique to the Lightning. At one point my last two ICE F-150s did the same.
jetfixr1
Anthony
Atlanta
This is my first Ford. Glad it's so easy!
I can tell you now the turn signal stalk will also go at one point, my last 2 gave in within 3 years ?? But thats probably more so from water intrusion when the rain comes in. Must be a Florida problem.
mattskr
Matt
Austin, Texas
23 Lightning Platinum, 25 Armada, 26 Wrangler JLU
I just recently had the same issue and I guess I disabled it in frustration by messing with the buttons.
Never had an issue with turn signals but on both of my last 2 F-150s the sunroof got stuck in the half open position upon opening it. I've now learned to no longer use the sunroof once the warranty expires.
SC_Sparky
Doug
23 Platinum Black
Had the same issue, dealer said it's common with F-150's and reset it. No issues sense.
MaintGrl
Marsha
El Sobrante, Ca
Ya, I found this out when I Installed my Weathertech Wind deflectors. It would go up, then immediately reverse. Quick fix for that
