Lightning FORScan HCM spreadsheet
EdNewman
Edward
Viera, Florida
24 F150 Lightning XLT, 22 Expedition 304A
Firearms Manufacturer
Ok, got to the bottom of this. First off, per the order guide the speed limit sign recognition is a standard feature on the PRO and up (so all levels) in 2024. That said it was not enabled on my truck. If you have a 2024 and it is not working (check the for the setting on Sync first) you can either go to the dealer and fight with them or fix it in ForScan. Here is the info I used on my XLT to fix it in ForScan
IPC 720-03-02 xxCx-xxxx enables TSR (traffic sign recognition)
IPC 720-09-01 xxxx-xxxx-9xxx enables SLIF
APIM 7D0-09-02 xxxx-x5xx-xxxx enables TSR NCAP Adaptions
APIM 7D0-09-02 xxxx-xxxx-xDxx enables TSR
IPMA 706-01-01 xx4x-xxxx-xxxx enables SLIF feature
IPMA 706-02-01 6xxx-xxx-xxxx sets TSR mode (6= fusion of camera and navigation, 4 is camera only)
Good work. So do you have a camera in your XLT (below the mirror) or is it just using nav? I know there is a thread where folks added adaptive cruise to their XLT but I haven't read through it. They have to make Forscan changes as well - maybe the same ones you just outlined.
EdNewman
Edward
Viera, Florida
the trucks all have the camera and this is supposed to be enabled from the factory per the order guide but ford has made such a mess with their software it was not. I tested camera only and it works but is more functional in the fusion mode with the nav data.
