nottelling56789
Looking to buy a Lightning Flash. Part of the driver is that complimentary Ford Pro Charge station home install as we are definitely going to try and snag a Kia EV9 when they starting hitting the lots….so figured great we will already have a home charging station..but now it seems the 2026 Kia’s are going to have the NACS port. Lightning has CCA(I am brand new at this EV stuff so forgive me if I’m hilariously using terms wrong). Now I’ve obviously read you can get an adapter to use a NACS station to charge CCA port…but looks like you can’t go the other way around with CCA station to NACS port and there’s no adapter for that scenario?Even then I’ve also to my dismay seen this isn’t as easy as “plugging it in” and you need to mess with apps etc so even if you COULD CCA charger to NACS adapter it could be a pain in the A software wise? Funny enough the specs for the Ford Charger Pro say “with a commonly available adaptor” you can use it to charge Tesla…because that isn’t vague…
