Seavee33
Miami, Fl
'13 F-150, Ordered 2021 Lariat
Electrician/ Project Manager
Hello. where can i download the forscan program and how do i get the "license"?
Thnaks
apMechorse
Steve
Fargo, North Dakota
'21 Ford Lariat 5.0L FX4; '14 Chevy Spark LS
Aircraft Maintenance Manager
Livnitup
Livnitup
2021 F150 Platinum
Can confirm that Digital Engine/Coolant temp & Transmission Temp (720-07-01) works; Keyfob Panic Button (726-62-01) works; and Keyfob Panic Alarm (726-01-02) works.
As you suspected I could not get Digital Oil Pressure (720-07-01) to enable, nor could I get Keyfob Car Finder (726-28-01) to disable this time either. I was also unable to get the startup tone (doo-do-doo) (720-01-02) to deactivate. I didn't get the drive mode message or anything. The only effect it seemed to have was changing the first sound to the old school (think 2014 Escape) tone, then it switched back to the current tone. No big loss on that one, just figured I'd add to your growing list of results.
Try this for the Keyfob Car Finder: 726-24-02 xxxx xxxx **-- Feat_Cfg [AUDIBLELOCKFEEDBACK] [VEHICLE]: 00=Disable 01=Enable 02=INOP
apMechorse
Steve
Fargo, North Dakota
Disable (00) was successful, and does NOT interfere with mis-lock notification (ie honking if a door is not closed completely.) I did not attempt INOP (02) since Disable worked.
Thanks!
Tecdiver
Dana
Michigan, USA
2021 F150 Lariat PB
Corporate shill
Can you clarify? Are you saying you dont like the speed limit sign on the cluster? If so, why not? I love knowing what the speed limit is especially if police are in the area.
I think the OP was referring to the bed-view camera, that switches off after ~9mph.
Seavee33
Miami, Fl
New to the forscan world and just need a little clarity.
Has anyone been able to recalibrate their speedometer to compensate for bigger tires?
Seavee33
Miami, Fl
jdesa05
J
New Jersey
None
I can confirm I changed DRLs to fogs, turned off DRL low beamon a XL with halogens.
matts11211
Matt
Boerne tx
2021 Ford 150 Lariat Hybrid power boost
Can anyone tell me if you’ve figured out how to disable the side panel in the 2021 f150 sync 4? Would love to have CarPlay or whichever app I am in to be full screen on the 12” screen.
jwgreene
James
Chattanooga, TN
2021 F-150 XLT supercrew in leadfoot with 5.0
Is there not a new version of Forscan where you can read each item and enable/disable/change each by line item instead of going in and changing numbers?
KartRacer25
Richard
San Diego
2021 F-150 SuperCab Sport 4x4 5.0 3.73 Space White
Senior Software Engineer
Just double checking this is correct/best/most reliable part to order:
Is there anything else I need?
Anyone figure out how to disable cylinder deactivation yet on 5.0?
Thanks in advance.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? ForscanCapture.JPG
apMechorse
Steve
Fargo, North Dakota
Just double checking this is correct/best part to order:
Thanks in advance.
That is correct. This is the cable that I bought and I have had zero problems with it.
Other than the cable, just the software and a license. Both of which are free and can be found by following the links that Livnitup has listed in his tutorial in the first post.
As for cylinder deactivation: No, to the best of my knowledge no one has been successful in deactivating it yet. At least not that has been posted on here or on the other forum.
Not as of yet. Again, based off of what has been posed here and the other forum.
Is there not a new version of FORScan where you can read each item and enable/disable/change each by line item instead of going in and changing numbers?
The current version apparently has two modes of operation, "Easy" and "Advanced," however as Livnitup mentions in his tutorial, I have only used the "Advanced" option as it makes incorporating other people's finding easier and faster than waiting for an updated version of the software to come out.
jwgreene
James
Chattanooga, TN
There is a video on youtube from a couple of guys who have figured out how to disable the cylinder deactivation. Seems very simple as its just a fuse at the batter that you disconnect.
