Got a dealer PPI today. Modules need updates?
DeePagne
vw
They didn’t explain this well. Probably because the guy at the desk admitted he is from the quick lane.
below is what they found. I am just trying to figure out if this is normal for 30,000 or a concern.
17 modules have available updates “ford will only warranty updates for TSBs and failures”
Coolant low
Left side hybrid battery bracket bent
Codes for air dam and sounder inop
front drive axles wet
this is a ‘23 Lariat ER with max tow with 31,000 miles
Im on the 7 day Carvana trial. Love the truck. Just need to know if it is good to buy.
what are your thoughts? Thanks!
Modules requiring updates isn't an issue, except that it should be updating OTA.
The left side battery bracket being bent is a warning of how the owner used it. The drive axles being "wet" would have me walking.
COrocket
F-150
Coolant Low - is a tough call without knowing the history, it could be over several years you lost a few ounces to evaporation which is an easy top off. Or there is a small undiscovered leak somewhere. I would carefully top it off to the max line and check right before the 3 year warranty expires to make sure you didn't loose a substantial amount of fluid if you decide to keep the truck.
Battery bracket bent - obviously abnormal, but you'd have to clarify if there's any surrounding damage and if they recommend replacing the bracket or if its minor enough to just let it be without impacting the functionality, and whether that bothers you.
For the sounder (I assume the pedestrian alerting speaker) this could have easily been disabled by the previous owner and the speaker may even be missing. The speaker could be either plugged in (if present), replaced, code ignored, or there's a company that makes a resistor to trick the truck into thinking it's still there without making any noise. The truck should function fine either way.
There was an air dam issue that was fixed with a software update, but realistically the truck will also function completely fine without it working. The air dam simply deploys at highway speeds to slightly increase the aerodynamic efficiency of the truck. It's nice to have and would be fixed under warranty if you pursued it. You *might* have success with the dealer software updating the module that controls the dam in an effort to fix the problem.
I would ask the dealer if the front drive axle leaking can be replaced under warranty as well. I would certainly address it before it gets worse, just be cautioned that you might be looking at a bit of downtime with this one vs all the other stuff. Figuring out a game plan with the dealer in regards to this issue is the sticking point of the deal IMO.
DeePagne
vw
Well, now the report he printed out says “slight leak front drive motor seals”
that sounds bad. Also heavy rust and pits on rear rotors
I would buy from a Ford dealership, and make this part of the sales contract:
"Perform all updates in FDRS, until such time as no updates remain. Print proof."
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
Where do you suggest buying a truck from?
Did u have it delivered or did u pick it up from a Vending machine?
I’d reach out to the Customer Advocate that u dealt with. They’ll probably have u reach out to SilverRock. If they cover everything I’d say a good buy. If… lol
DeePagne
vw
So if they covered everything you'd think it's still good to buy even though it seems like it was driven hard?
Ted23Lightning
Ted
As long as Ford did a thorough review of the vehicles condition. That’s kinda the main positive about Carvana. If you have it inspected by the dealer or one of SilverRocks preferred shops, they can’t really deny the repairs/ replacement. Carvanas multipoint inspection is a joke. Their techs are given very limited time to inspect the vehicles. And on an EV, I wouldn’t trust them at all.
An example of this is we had a few Hyundai engines die while in inventory & they had the engines replaced. Customer then ended up with a brand new engine. Albeit, it was still a Hyundai engine lol
jetfixr1
Anthony
Atlanta
2023 F150 Lightning Lariat ER
Uffff, those silver rock people have been known to have unethical business practices. Tons of horror stories online. Hard pass.
Ted23Lightning
Ted
Definitely hit or miss. That’s why I was saying IF they cover it lol
And if they don’t, just have them come pick it up. Buy another Lightning somewhere else.
Ragman
Coolant low is nothing new, that's why it's on the "maintenance' checks with rotate tires. The others depends if warranty will cover. There is a '23 Lariat ER Max Tow on local Ford dealers lot for $40k US ($60k Cdn). If you are getting it from Carvana for $30k US then go for it - if you are paying full dealer list then pass.
DeePagne
vw
is that a website?
This is a ER with max tow and blue cruise. It was $49k before tax
flyct
Jerry
South Florida
Blissfully Retired
Coolant low
Don't hesitate to notify them that you want to return the truck
https://www.carvana.com/help/purchasing-a-car/what-are-the-limits-of-the-7-day-money-back-guarantee
The 7-Day Money Back Guarantee begins on the day that you receive the vehicle. To return or exchange your vehicle, you must notify us before 8:00 p.m. EST on the 7th day. You can exchange up to two times to receive a total of three vehicles. However, the third vehicle received will NOT come with our 7-Day Money Back Guarantee and cannot be returned or exchanged if you accept the vehicle at your appointment.
Vehicles may be driven 400 miles within the 7-Day Money Back Guarantee period. If the vehicle is driven over 400 miles, you will be charged $1.00 per mile for each additional mile.
Shipping charges are nonrefundable regardless of any return or exchange facilitated. Please be aware that vehicles sold or traded into Carvana will not be returned. Learn more.
