Anyone have Siri Shortcuts for climate start working in 2025?
Jackdforme
Barry Allen: 2025 Ford F150 Lightning Flash
I’m a pretty technical person. I changed the API command from post to get just to see if I’d get a response from Fordconnect for the token, etc..
No matter what I do, the best outcome I have is "cannot start the vehicle."
Is this disabled from the Ford Connect side? Did they secure the API in some way? Does anyone have this working and can show me the newest set of shortcuts that work?
I’m coming from Tesla and have gotten very used to starting my car with my voice. I do not use Amazon services so that’s not a starter.
Thanks for any help all.
Trying to understand your question.
Do lock and unlock work, but not start?
And are you asking if that unsupported API still works for 2025 model year trucks or if it still works in the year 2025?
Jackdforme
Jackdforme
thanks for the reply.
Ford has native shortcuts for lock/unlock and that works fine. For a few years, owners have hacked the API calls that the FordPass App makes anyway through a combination of IOS shortcuts. There are threads on it. The problem is that the process requires two tokens to be generated as a "pre-step". That step seems to either not collect the token from the ford vehicle connect site or some other failure. The Get FordPass Token and Get Autonomic Token steps either hang entirely on using the shortcut with API "POST", or complete with seemingly no information returned for API set to "GET".
I know this is kind of technical but wondering if I am missing something or if this has since stopped working for anyone who does use the shortcuts.
When working, you get Start, Stop, Odometer, SOC, etc..
GERGreg427
DFW, TX
2023 Ford F-150 Lightning; 2022 Ford Explorer Limited
IT, Photography, Web Design
From what I have seen on home assistant, the api has changed to a device key style setup and no one has figured out how to get it to work on anything. I could be wrong but that is what I have been dealing with there.
MountainAlive
Massachusetts, USA
2023 F-150 Lighting ER 512A Max Tow
Hopefully soon there will be AI agents where you simply tell it to do something and it’ll just open the Ford app and click on the button for you as if it were you doing it. You know, just before these AI agents bring about Terminator 2 Judgement Day.
I have Home Assistant working fine including remote start. It does take some setup using browser tools to obtain an authentication token.
Jackdforme
Jackdforme
Its interesting that they are planning to allow it from the lock screen and action button. Perhaps this will enable the use of a shortcut (hopefully simpler and native) for start/stop.
Jackdforme
Jackdforme
thank you for the details here. This makes a bunch more sense as to why it won't return the payload.
Jackdforme
Jackdforme
This is to start as Lock/Unlock are now supported natively.
