OtterJohn
Philomath, OR
The missing slider on your Charging screen is weird. Searching the whole Internet for “FordPass target charge setup” there are many issues. Yours may be slightly different but here are things you might try:
  1. Uninstall, reinstall FP app
  2. Delete your home location in Charge setup. Delete your Home location in the Nav settings. Setup both again. Will have to likely initiate a charge to set a “new” location.
  3. Same as 2 but disconnect 12V battery for a few minutes after deleting Charge location Home and Nav location Home. Then setup again.
When deleting charge locations make sure they show deleted both on app and in vehicle.
One other thing. In the app, when you go to the Energy tab, then Target Charge > Home > do you see the text below the slider that "Target Charge Levels can be adjusted during a charge session..."
Nope, no slider on the home target charge page either. I’ll try the uninstall/reinstall (I’ve been in IT for 35 years, you’d think I’d have done that first… ?).
ChippewaBarr
23 Lightning Platinum Agate Black
Last few updates (on Android - using a Pixel 8) have been pretty rough for us.
We always use our phone for the truck unlocking and as a key but the consistency is all over the place.
Prior to this update the PaaK wouldn't unlock the truck via proximity (would if done in app) but would be fine to start the truck via proximity.
Now it's the opposite and the truck will unlock when I come near but when I hit the start button dash just says No Key Detected.
Anyone else have these issues? It's a major pain in the ass lol.
kzoojason76
Jason
2024 F150 Lightning Flash
Is anyone else seeing an erroneous "Charging Problem" error in the new FordPass app? I've gotten the error a couple of times, and each time I go out to the truck, it is charging just fine.
K6CCC
Glendora, Calif.
Nope. Charging right now on a J1772 charger for the past 4.5 hours and it's working fine. Charged yesterday afternoon after getting the 5.21.0 app version in the morning, and that also went fine.
kzoojason76
Jason
OK, thanks! I'm just going to keep an eye on it. It doesn't seem to be a problem at the moment. If I keep getting them, I may uninstall/reinstall.
Scorpio3d
SS/IBA car wash owner
I got this one, but I was on vacation in Mexico and my truck was at the airport at the time??
This was prior to the new version of Ford pass…
Ford F-150 Lightning FordPass 5.21.0 iOS & Android IMG_1878
OtterJohn
Philomath, OR
Got it sorted. Removing and re-adding Home didn't help, but the uninstall/reinstall of the app brought the slider back. SMH...I should know better, this is "my app's not working 101"...
doggod
Jef
Mendocino County, California
cybertruck, f150 lightning, 911 turbo s
since they moved the Amperage slider to the ford pass app it has never worked for me. can you show me pic of your changes actually working? like pic of amperage and pic of watts into truck. then change it and show it actually lowers watts to truck. I have solar and it shows truck using same amount as the hardware setting in ford charger. so does the fords app show truck using same amount of watts, even though amperage setting shows lower rate.
