K6CCC
Glendora, Calif.
Try going to the app store and search for Ford pass, then update if gives you the option. That was what I did yesterday.
Sometimes force stopping the app first helps too. Done all that, not yet available for me yet either.
Same, Same.... it's just not reached all the dispersed distribution nodes, it'll come in due time.
timsnart
Chanjai
New Jersey
2022 F150 Lightning Lariat
small business owner
Android is still at 5.20.0
Just got 5.21.0, weirdly, when I checked several times earlier today it was not queued up as of yet, nor was it on this most recent check, so I went into the details of the app via PLAY STORE, scrolled through the details & description, then expanded this version details, scrolled further and there it was a summary of 5.21.0 that hasn't as this viewing been installed.
I exited up the menus to find it now listed as available for manual selection and installation, i selected it and let her rip.
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750173521909-6t
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750173549956-5r
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750173615745-si
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750173576381-9m
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750173642313-6u
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750174174540-9u
Widget is now available
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750174001903-ij
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750174024081-47
K6CCC
Glendora, Calif.
Two hours ago when I checked, it was not available, but sure enough, but now like TaxmanHog, I have 5.21.0 available. Loaded it and added a shortcut to start climate control...
abcut973
Anthony
Denham Springs
Same here it has landed for me as well! ?
doggod
Jef
Mendocino County, California
cybertruck, f150 lightning, 911 turbo s
I get my updates with TestFlight. been running 5.21 for a couple of months now. it did not fix the Amperage adjustment or ability to change max charge when on DCFC.
remote start is a joke as you are not able to drive the truck without the key fob anyway. only useful if you have something plugged into power and need power to be on.
Not sure which version I was on yesterday. I changed the charging schedule on my phone and it took effect within seconds. That was nice. My FCSP also seems to be responding to my adjustment for max Amps. It was 113F yesterday so I'm lowering the Amps to help avoid overheating.
OtterJohn
Philomath, OR
Finally home and got some screenshots. Plugged in, and there's no slider. Then I had to go into Target Charge for my home and change to 100%. It does NOT revert back to 80% once I unplug. Still not sure why I'm not seeing the one-time charge slider when others are not having this issue.
Ford F-150 Lightning FordPass 5.21.0 iOS & Android IMG_5625
Ford F-150 Lightning FordPass 5.21.0 iOS & Android IMG_5626
Lake Placid Lightning
2023 Lariat SR w/510A
Civil Engineer
"Siri, ask FordPass for my charge level." and "Siri, ask FordPass for my charge status."
Both commands above return, "FordPass hasn't added support for that with Siri."
Using FordPass v5.21.0, iOS 18.5
The missing slider on your Charging screen is weird. Searching the whole Internet for “FordPass target charge setup” there are many issues. Yours may be slightly different but here are things you might try:
  1. Uninstall, reinstall FP app
  2. Delete your home location in Charge setup. Delete your Home location in the Nav settings. Setup both again. Will have to likely initiate a charge to set a “new” location.
  3. Same as 2 but disconnect 12V battery for a few minutes after deleting Charge location Home and Nav location Home. Then setup again.
When deleting charge locations make sure they show deleted both on app and in vehicle.
One other thing. In the app, when you go to the Energy tab, then Target Charge > Home > do you see the text below the slider that "Target Charge Levels can be adjusted during a charge session..."
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1750255149775-1n
She seems to be quite sensitive to the phrasing. Try (via @GDN's post 3):
"Siri use Fordpass to tell me how much charge my truck has"
Civil Engineer
Thank you, that worked.
I tried substituting "Siri" for the "Alexa" commands you listed in Post #4
