Kev12345
2023 Pro ER
Remote Start?? It's Electric :facepalm:
I want to remotely view camera's, have blinker cameras, maybe even YouTube on CarPlay when charging.
You guys know that Tesla's have no start button, no keys. You know all of that silly ICE stuff can go away.
Chevy knows
OtterJohn
Philomath, OR
Not sure if it's specific to this version or not, but I have lost the ability in the Energy tab to do a one-time bump in charge level. Used to be a slider at the top of the page. I usually charge to 80% daily, but was going to bump it to 100% last night for a trip today...that option is nowhere to be seen. You can permanently change the charge level in the Target Charge setting for your location, but that's it...otherwise it had to be done from the vehicle screen.
Anyone else having this issue?
2023 Lariat ER
Jreed
Jeff
El Segundo,CA
2023 Ford Lightning ER Lariat Avalanche
Retired Engineer
Yes I am having the same problem. I had to go into the truck and change the one time charge percent number in the Charging app, very inconvenient. The slider has disappeared.
K6CCC
Glendora, Calif.
Interesting, I do have 5.21.0 on my#$%^& iPhone and the charge slider is there. In fact when I changed it from 100 to 95% on the iPhone, the change was shown on my Android within a few seconds. Then on the Android, changed it back to 100% and that was reflected on the iPhone within a few seconds. I won't be here anywhere near long enough to reach either 95 or 100%
I do not have 5.21.0 available yet for my Android.
Apparently this was changed/removed some time ago, not just this release. See this thread. It asks you if it's one time if you move to 100%. @OtterJohn @Jreed
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1749847392206-7v
Then if you click One-Time Only, you get this:
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1749847731771-9
K6CCC
Glendora, Calif.
What are you taking about then? I still have both the slider on the Energy tab during a charge session (right image), and the target charge for a location (left image):
Ford F-150 Lightning FordPass 5.21.0 iOS & Android Charge limits
This on my #$%^& iPhone with 5.21.0
Yes, I have that too.
But IIRC, there used to be an explicit button or slider for a one-time charge setting.
These sliders imply that you are changing your Home setting (permanent). Only if you go to 100 do you get the one-time only prompt.
EDIT: From Reddit 8 months ago. The slider was labelled differently and only for one-time.
Ford F-150 Lightning FordPass 5.21.0 iOS & Android 1749851319306-9
I <3 My Lightning
'23 XLT ER 312A Oct. build date
The new auto display of chargers as you move around the map is a welcomed addition. I hated having to constantly tap search here, even for a little movement of the map.
jjupi91897
Joseph
2023 Lariat ER
It is still working on mine.
Ford F-150 Lightning FordPass 5.21.0 iOS & Android Screenshot_20250613_220630_FordPass
OtterJohn
Philomath, OR
I guess I didn't explain well (that's on me).
On the Energy tab, after plugging in, there used to be a slider to change the charge level, and you'd be prompted to make it a one-time change or permanent. That is no longer in my app.
I do have slider like @jjupi91897 shows above, in the Target Charge setting. I assumed this was the permanent change, but this morning that setting returned to 80% after I set it to 100%.
So regardless, I no longer had the one-time slider where it used to be. When I'm back home on Tuesday and plug back in, I'll monkey with it some more.
K6CCC
Glendora, Calif.
Look at my post #36. That was taken this morning with 5.21.0 on my @#$%^ iPhone.
Nice to see the Android version hitting the street, still waiting in my corner of the universe.
Right; it's just odd that it's gone from mine...
At this point, it would be useful for you to attach a screenshot of the charging tab once you plug in. It doesn't appear you are seeing the same thing in posts 35,36,37, or the link I posted in 35.
As mentioned in post 35 and the link there, the slider was renamed some time ago. Are you saying you don’t have any slider?
Reactions: GDN
