Moon Roof creaking.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
So I have the creaking/ bumping sound coming from the rear of the moon roof. Read a few threads on here about the screen being the culprit. Mine is the rear of the glass panel creaking. I can push up on it and it makes the little thumping noise that's been driving me crazy for a few months now. I tried tightening the torx bolts that run along each side, but that did nothing. Anyone else run into this? A solution.
Iroc34a
Iroc34a
Roc
Never mind. Right after I posted this. The thread on cleaning the rear seal or lubricating it popped up. I'll try that tomorrow. Sounds like exactly the issue have.
vic7780
Victor
Quantico VA
F-150 Lighting - Atlas Blue, Max Tow, 511a Package
Citizen
Can you post the link to that thread here?
jetfixr1
Manny
Atlanta
2023 F150 Lightning Lariat ER
Being that the sunroof is so finicky, I religiously perform that TSB every 6 months usually in the fall and spring. 1 tube of the Krytox is good enough for the whole year. I also clean the drains out with warm soapy water and this drain brush from amazon
Ford F-150 Lightning Moon Roof creaking. IMG_1025
K6CCC
Glendora, Calif.
Two Way radio systems
Makes me glad I do NOT have the moon roof.
Iroc34a
Iroc34a
Roc
Exactly what the noise was. A little silicon spray into the seal. And noise disappeared. Thanks men. And the drain tool is next on the list.
