Dome light wire?
hstrip
Heath
2023 Pro
Commercial AV
does anyone know where I can tap into a dome light wire? I have some lights that I want to put in the foot well area. I used to install alarms in cars years ago and it was pretty easy to find the dome light wire in the driver kick panel. But I have been unable to find it in the lightning.
I'm not sure what the Pro has. I know the Lariat and above already have footwell lights. Do you have a light inside your center console?
Otherwise the BCM has a courtesy wire (gray w/ violet stripe) but that is entry/exit only. BCM also provides an on-demand light circuit (switched lights like dome, bed, vanity mirror, etc.) It is Yellow-green. It is always on but tied to battery-saver (off after 30 minutes).
Or do you want the illumination circuit (always on at night)?
djhawaii
Robert
2025 Ford F150 Lightning Lariat
IT Solution Dev/DBA
Are you trying to install leds inside the truck. If so on the rear drivers side under the plastic foot plate, you can tap in to the Grey/Violet strip wire and the black/violet ground wire
hstrip
hstrip
Heath
2023 Pro
Commercial AV
Yes. I tried to find these and didnt have any luck. I found a grey/violet but it didn’t test with a volt meter. I am trying to install leds inside.
djhawaii
Robert
IT Solution Dev/DBA
It took me a while to find the correct wire. The correct wire only has hint of violet
Ford F-150 Lightning Dome light wire? led
