Dome light wire?
hstrip
Heath
2023 Pro
Commercial AV
does anyone know where I can tap into a dome light wire? I have some lights that I want to put in the foot well area. I used to install alarms in cars years ago and it was pretty easy to find the dome light wire in the driver kick panel. But I have been unable to find it in the lightning.
I'm not sure what the Pro has. I know the Lariat and above already have footwell lights. Do you have a light inside your center console?
Otherwise the BCM has a courtesy wire (gray w/ violet stripe) but that is entry/exit only. BCM also provides an on-demand light circuit (switched lights like dome, bed, vanity mirror, etc.) It is Yellow-green. It is always on but tied to battery-saver (off after 30 minutes).
Or do you want the illumination circuit (always on at night)?
djhawaii
Robert
2025 Ford F150 Lightning Lariat
IT Solution Dev/DBA
Are you trying to install leds inside the truck. If so on the rear drivers side under the plastic foot plate, you can tap in to the Grey/Violet strip wire and the black/violet ground wire
hstrip
hstrip
Heath
2023 Pro
Commercial AV
Yes. I tried to find these and didnt have any luck. I found a grey/violet but it didn’t test with a volt meter. I am trying to install leds inside.
RLXXI
3rd rock
Automotive Technician
The circuit is ground pulse modulated so when you do find the wire, make certain your lights are compatible with that type of circuitry or you're going open a can of electrical worms.
djhawaii
Robert
IT Solution Dev/DBA
It took me a while to find the correct wire. The correct wire only has hint of violet
Ford F-150 Lightning Dome light wire? led
