ZSC100
I have a project going on right now (independent of charge while driving) that allows a Lightning or MachE pack to be used an alternate battery storage stand alone. The current design will be a small HMI solution, the battery and one of the on board chargers That's it. I will post on this forum when it progresses a bit farther, it's a design project for EE students at a local university and we are going to make everything open source.Single cells? The lightning is pouch cells.
Maybe disassemble to packs and work with those as an option,
But the easier way with solar is use the full 380VDC as an alternate "PV input" since the inverter will only draw what it needs, and typical Inverter input can handle any DC voltage between 200-500VDC. Use the original battery charging sustem for recharging the battery and everything will work and balance as designed.
