NW Ontario Ford Lightning
- First Name
- Robert
- Feb 14, 2025
- NW Ontario Canada
- 2024 F-150 SR Lightning XLT
- Occupation
- Contractor
Single cells? The lightning is pouch cells.
Maybe disassemble to packs and work with those as an option,
But the easier way with solar is use the full 380VDC as an alternate "PV input" since the inverter will only draw what it needs, and typical Inverter input can handle any DC voltage between 200-500VDC. Use the original battery charging sustem for recharging the battery and everything will work and balance as designed.
