F150Redux
Daniel
2025 F-150 Lightning Lariat
Computer Geek
In August I was selected as the winner of the @Redtiger "Share Your Road Trip Map" (https://www.f150lightningforum.com/forum/threads/redtiger-giveaway-share-your-road-trip-map-—-win-a-dashcam-plus-more.29843/) giveaway. The prize was a Redtiger F17 Elite plus the Hardwire Kit.
Notes:
- I've never used a dashcam before, so I don't have any firsthand experience to compare to
- Usually, I don't do much to my vehicles, but for my new 2025 F-150 Lightning (Lariat) I'm doing a bunch of different things
Details
REDTIGER F17 Elite 4K 3 Channel Dash Cam Sony STARVIS 2 Dual HDR WIFI 6 Full Night Color
  • Native 4K:4K+1080P+2.5K 3-Channel
  • 10X Faster WiFi 6 (5.8 GHz):Max 30M/s.
  • Night as Day :Offering 24/7 Ultra-color
  • Always Clear:Dual STARVIS 2 with HDR
Unboxing
The F17 Elite arrived via U.S. Postal Services a few days before the expected date. The dashcam and hardwire kit were enclosed in a light-gray plastic shipping bag. After opening I saw that the dashcam box had a small dent in one corner, but there were no issues with any of the contents.
The dashcam was in a box, and the hardwire kit was in a separate bag.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 007
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 008
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 010
The F17 Elite box is well organized and provides a great "unboxing" presentation. You're first visual is a vellum-like transparent diagram of the F17 Elite dashcam. Lifting that out you're presented with the hardware on the bottom and the instructions and accessories, in three separate boxes, on the top.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 012
The instruction box contains: F17 Elite User Manual, APP Quick Book, and four electrostatic stickers used for mounting the front and rear dashcams.
The other two boxes contain:
- Power supply cable with car charger and trim push/pry tool
- Rear camera cable, cable clips, and adhesive
I read through the manual and app booklet quickly to get an initial handle of what everything was and to prepare for the installation a day or two later.
Installation
Before beginning the installation using the hardwire kit, I tested the cameras using the included power supply cable. At first, I just plugged in the front/cabin dashcam (the main unit) and turned it on. It came up with no issues and started recording on the included 128GB SD card. I then plugged in the rear camera and that became active.
Hardwire Kit
I opened up the hardwire kit and quickly read that manual. The hardwire kit includes a voltage sensor, with display, that you can set to automatically turn off the camera in undervoltage situations. I set this to 12.4V. This is handy if you use the "parking mode" and will keep the dashcam from depleting/draining your battery. This kit also includes eight different size fuse taps, a trim tool, and a piece of adhesive that you could use to mount the voltage sensor box.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 031
Wiring
I mounted the front/cabin dashcam in the center of the windshield, just below the mirror. I may go back at some point and move it even a little bit further down; I can see 85-90% of the camera unit, but the bottom of the mirror obscures the top edge.
The power cable from the hardware kit was plugged into the camera and then tucked into the plastic of the overhead/mirror unit. From there it went into the headline to the passenger side A pillar.
Taking off the A pillar was easy for me as I'd already done it to install new tweeters when I upgraded to Alpine speakers. You just take a small pry tool, insert it into the hole at the bottom of the grab rail, and gently pull the plastic insert out. Do it carefully so you don't scratch the trim piece. Once you start to get it out you can just pull it the rest of the way out -- be careful as the top part is connected with a little piece so it will hang in place. One you remove the insert you get access to two 10mm bolts. When those are taken out you can just pull down on the grab rail, and the A pillar trim will pop off/out. NOTE: Don't pull it too hard as the tweeter is connected and you may break the wiring. If needed, you can disconnect the tweeter wire and set the trim piece aside. I just stuck it on the dashboard while I continued.
I continued by running the hardwire kit power supply wire down the A pillar, behind the metal airbag supports, where I tucked the voltage sensor alongside the Alpine crossover circuit box. It was a tight fit, but both fit. If you don't have a crossover there, you'll have plenty of room. I did NOT use the adhesive on the voltage sensor.
The wire then continues down behind the weather stripping to the passenger footwell. I used the trim tool to push the bottom panel seam so I could get the wire into the fuse box area.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 036
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 037
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 038
I used the appropriately sized fuse tap in the following locations:
- #4 for constant 12V (the yellow wire to B+)
- #17-18 slot (red wire to ACC) - Note: The 17-18 slot is a MICRO3 slot; I used the MICRO2 tap and used the side closest to the 17/middle. Instead of using the original 7.5 fuse in the fuse tap I put in an extra 20A in that spot for the tap. The original fuse I put in a baggie in the glove box.
Both these locations are marked as "SPARE" in the Lightning manual and have fuses in those positions. Thanks to @Zprime29 and his review for pointing me in the initial direction.
The black wire for ground I put on the bolt in the top right corner of the footwell (I may move this to one of the bolts closer to the fuse box, but it's really tight in there/weird angle).
My first issue was determining which fuse was actually 12V constant vs Accessory. My second issue was that I broke one of the original 20A MICRO2 fuses when trying to move it around/test the fuse taps (really tight fit!!!), so I had to go to a couple different stores before I found the right replacement. While I was out, I bought a circuit tester which made life easier.
NOTE: While I was working through the actual wire connections, I tested the power to the main dashcam. I noticed while doing so that the voltage sensor showed the voltage, "ACC", and a countdown timer (60 seconds). So, it all seemed to be working as expected.
To wire in the rear camera I ran the cable up into the overhead/mirror trim; there's an empty hole there that makes getting the initial bit of wire in easier. Then across the headliner to the Driver's A pillar, down to the floor, through the kick trim channel, and to the back of the truck. There wasn't enough wire to go all the way up to the rear window headliner, so the cable comes out about halfway up and then angles to where I have the camera.
If I ever decide to move the main unit (as noted above) I might re-route the read camera cable and just go headliner all the way back.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 040
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 042
Usage
I haven't had a lot of time in the truck since installing the Redtiger F17 Elite, but what time I've had so far, it's easy to use. The controls are straightforward and intuitive. I did a couple short trips with the included 128GB SD card while I waited for a 512GB card to arrive from Amazon.
IMPORTANT NOTE: Don't do what I did!!! When the Amazon 512GB SD card arrived, I went to put it in. Easy peasy right? Just use a finger nail to slightly push in the original and let the spring pop it out. Then insert the new one. I went to put in the new one, was stretching my arm to get to it, pushed it in and my hand slipped... the spring EJECTED the card across the dashboard where it landed in the far corner between the windshield and the dash. I could see it from the outside, but there was no way in heck I was getting my hand in there. I ended up having to use some painters tape and a long narrow trim pick tool to fish it out of the crack. I guess I was lucky it didn't end up in some vent hole or completely behind/inside the dash. That would have been a quick waste of money.
The first video I got was pulling out of the driveway. There was a lot of glare picked up from the windshield and sun.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 1758940290452-4
When there's no glare the front camera is very impressive:
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 1758940394682-dj
The internal cabin and rear cameras are quite good as well:
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 1758940769976-s1
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 1758940683040-1j
Some low-light/night views:
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 1758941058261-9v
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 1758941164322-9h
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 1758941241281-qa
Initial Final Thoughts
I plan on updating this review as I get some more experience/time with the dashcam. But initial thoughts are positive. The hardware/packaging is all top quality. Installation went smoothly and pretty quick considering I'd never installed a dashcam before.
The dashcam itself is easy to use/navigate.
I did install the iPhone version of the app and quickly connected to the dashcam via its WiFi connection. I was able to see the cameras and recorded files.
When I have more time with the app and the dashcam itself I'll tweak the settings and report my findings here in this review.
Additional updates (links to other posts in this thread):
- Firmware Update Process (https://www.f150lightningforum.com/...ite-installation-and-review.31168/post-576228)
Rice_classic
Rice
2023 F150 lightning lariat ER
A couple things for the greater audience playing along.
1) That passenger well fuse panel is great. Easy to access, and with a voltmeter, easy to identify which open slots are 12v or ACC.
2) the add-a-fuse things have a correct and incorrect orientation. So when you are checking the voltage at the fuse slot with your voltmeter, check which side is hot vs not and that will determine the orientation of the add-a-fuse. https://www.blackboxmycar.com/pages/fuse-facts-the-right-way-to-use-an-add-a-fuse
3) Question for OP - does this camera run while parked and if so, does it have an automatic shutdown at a given voltage? I use BlackVue cameras and have mine set to turn off at or below 12.5v.
F150Redux
Daniel
Computer Geek
1) I agree the passenger fuse box is pretty easy to access. Would be even easier if you could remove the rounded/front trim piece to get in there. Otherwise, you have to contort yourself to see around it.
2) Did not know that. I just followed what @Zprime29 had mentioned.
3) There is a parking/guard mode but I haven't looked into it yet. The voltage sensor I mentioned is used for that and to shutdown the camera as mentioned in my post (i.e., giant wall of text).
My brother warned me about the orientation for the add-a-fuse adapters. I remember trying to check the fuse slots and it being a real pain as I couldn't get that front bit of trim to come off. I can't remember for sure if I was successful or just gave up and called it a day since it was hot. Probably wouldn't hurt to double check that, I need to find some better lead though. The ones I have are so short that making good contact was difficult.
I have the same hardwire kit on mine, the voltage box has a switch on it to select when you want it to cut off. 12.3 - 12 - 11.7 are the options. I chose 12.3 as I don't anticipate needing to use it for long periods of time.
F150Redux
Daniel
Computer Geek
My Redtiger contact emailed me the other night and let me know there was a firmware update available for the F17 Elite dashcam. This morning I some had time so I installed it.
I took some screenshots from my iPhone and a couple pictures of the dashcam to document the process.
First, I connected my iPhone to the dashcam's WiFi. On the dashcam I activated the 2.4Ghz WiFi and then connected to it through the Redtiger app.
I was presented with the "NEW" icon for the dashcam and could view the current version.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 004
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 005
Clicking into the dashcam I was prompted to "Download and upgrade":
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 006
The firmware update took 2-3 minutes to download to the phone and then I was prompted to send it to the dashcam:
It took maybe a minute to send the firmware to the dashcam:
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 009
The dashcam had a message on it asking if I wanted to update (I wasn't able to get a picture before it went away) which was a little confusing. But once the firmware was pushed to the dashcam the update started automatically:
It took 1-2 minutes to complete and the dashcam restarted automatically.
Ford F-150 Lightning Redtiger F17 Elite - Installation and Review 011
Upon restart it looks like you lose your settings. I had to choose the language and then re-enable the DST setting to get the clock to be set properly. I'll have to look into it more to see if it actually saves/restores settings, or if you have to "start over".
If it doesn't save the settings, again I have to research/test some more, it would be nice if you could save/load them to the SD card to make it quicker.
Overall, the firmware update process was quick and easy.
daczone
2024 Lightning Lariat
Thank you for the great review.
I just grabbed the Redtiger F7NP (Same camera just lacking the interior cam for $85 on sale. Oddly the LED screen is larger on the cheaper model. Sad that our truck with all of the factory camera's don't interface to the Ford app, or get recorded to give us a built in dash cam.
Anyone wanting to save a little money... take a look: F7 vs F17
F150Redux
Daniel
Computer Geek
Just to clarify, the F17 is different than the F17 Elite that I received and reviewed. From a quick Google search:
"The main differences are that the RedTiger F17 Elite is a flagship, three-channel dash cam with a 4K front camera, 2.5K rear camera, and a 1080p full-color interior camera, featuring advanced Sony Starvis 2 sensors and Wi-Fi 6. In contrast, the standard RedTiger F17 offers a 4K front camera but a Full HD rear camera and an infrared cabin camera. The Elite model provides superior night vision, faster connectivity, and a more advanced interior camera for a more premium and comprehensive recording experience."
daczone
The Quality of this device is amazing... But the cheaper version. ($85 on sale when I bought it 2 weeks ago, now $129) only comes with just a 32G memory card.
I just ordered a 256G card ($24) after finding out the 32G card recorded approx 4 hours of video front (3840x2160) and rear (1920x1080). The Quality is GREAT. This morning on my COSTCO run I had a Ford F-150 in the oncoming lane sliding sideways towards me. I had plenty of room to stop, but had I been a few seconds further on the road he would have hit me. I didn't try to grab the video until I got back home. I'm glad I found this out now. Of course in the TESLA you just hit the horn and the recording is saved. If you are in an accident the video is saved in an a Urgent folder, basic function of the device. Now with the 256G card I should have over 32 hours of recording.
VAL.ABAPO
2025 F150 FLASH LIGHTNING 131kwh ER
#4 Fuse doesn’t give me constant 12.5 volts. It drops down after initial reading of 12.5. What could be wrong?
