Naveen
- First Name
- Naveen
- Aug 12, 2025
- Louisville, Kentucky
- F150 Lightning 2023 XLT- 311A
Thank you for your reply. I took the plunge this weekend and installedAhhhh yes I remember that bracket. It's been a while.
1) Wiring harness in front bumper
2) Added Radar
3) Updates Forscan
After all this i still couldnt make the CCM module come up.
After struggling with Forscan for some time , i took a look at wire harness connecting bumper to car and seems like missing in that
Man it was so disappointing to know after doing everything else.
Hey @ZSC100 Good Morning, Heop you are doing well.I used to think differently about all this, OEM all the way, but I've changed my opinion. You should totally go least path of resistance. Get 4 lever nut splices and snip the wires a few inches from the IPMA and run your own 4 wire harness out to the CCM at the bumper. You won't need to remove the bumper, just poke the wires through where they go and splice on the CCM pigtail. I could literally install it like this in 30min.
Yes, all you need is the CCM hooked up to the IPMA and the FORScan changes.
This work as I've explained it has been so proven by now it has zero chance of affecting anything related to warranty on a truck, if that's even a worry.
If you are good with splicing and running wire, do it this way and don't look back.
Man i took the plunge this weekend and did below listed things
1) Added RADAR to Front Bumper.
2) Replaced Bumper Harness with new one
3) DId the ForScan update.
This took around 5 hours for a novice like me ! At the end i was not able to see CCM module coming up in ForScan.
Did everything again but still no luck. At the end checked the wire harness connecting Front Bumper to CAR and found out that I dont have required wiring there :-(.
SO i see required wire on Driver Side, PassengerSide but not on Harness connecting FrontBumper to car.
After doing everything else its extremely disappointing to see. Can you please help me out here ? Sorry Im not very knowledgeable about wiring .
If you could let me know what im missing and how should i go about it.. It would very helpful.
Thank you
Naveen
