Alarm randomly went off
chuck27p
Chuck
Orange County, CA
2023 F150 Lightning Platinum Black
I'm at work and hear a car alarm for 10 minutes and finally go outside to see that it's my lightning. It's parked and it doesn't appear anyone has been near it, which I confirmed with building staff. I couldn't get the alarm to turn off with the key, I had to get in the truck and start it for it to stop. This is the first time I've experienced this and wondering if it's a random issue I should ignore or a larger problem I need to look into. Has anyone else experienced this?
B177y
Olympic Peninsula, WA
What year is your Lightning (might want to add that to your profile) and what is the state of health of your 12 volt battery?
GarageMahal
JT
Data Wrangler
Possible rodent damage? This was the first symptom I had followed by several others but fortunately it was drivable. Dealer found the damage fairly quickly but took several days to get the replacement parts installed.
chuck27p
chuck27p
Chuck
Orange County, CA
I have a 2023, I added to profile. Battery seems ok to me, I just tested. No rodent damage.
Ford F-150 Lightning Alarm randomly went off IMG_1088
B177y
With a 2023, if it is still the original battery, that would be where I would focus. Even though it seems to be testing okay, 3 years seems to be the breaking point for our batteries. Weak 12 volt batteries tend to cause all sorts of weird random issues.
It may just be a one-off problem, maybe you sat on the alarm button or it just hit something perfectly and set It off? I have had that happen to me before, and I thought the same thing as you, "Why doesn't that person shut their alarm off?"
Reactions: chl
B177y
The more I think about it, I am leaning towards your 12-volt battery. You say you had to turn the truck on to stop the alarm. This makes me believe that once you turned the truck on, it activated the DC to DC converter which provided enough current to clear whatever error the low battery was causing.
Does your tester provide a load test on your 12 volt battery?
Reactions: chl
chuck27p
chuck27p
Chuck
Orange County, CA
I have been wondering if I should proactively replace the 12v battery actually. I am occasionally getting the screen waking up with a progress bar when I get in the truck sometimes (says something like "sleeping to preserve battery [progress bar]" which I haven't seen before. Just started about 2 months ago and it's every so often, not every time. And now this. Maybe I should just replace the battery. I know someone on this forum outlined how to do it and what to buy. I'll look it up thanks.
chuck27p
chuck27p
Chuck
Orange County, CA
Not sure, I can check later. But yeah, I'm thinking it's the battery too.
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
Insects can set off the interior motion sensor, although most 23s had the sensor deleted.
Pacific.NW
Christian
Vancouver, Canada
2022 Lightning Lariat ER
Mine does the same thing… (message), and also had the random alarm once in the middle of the night. You’d think with all the technology these trucks are packing it could just tell us what the problem was, or if it’s time to replace the battery.
chuck27p
chuck27p
Chuck
Orange County, CA
Did you end up replacing the battery proactively or have you left it alone? That's what I'm trying to decide. Is it worth the $ and hassle of changing the battery when it could be fine for x number of years (I don't like to replace things until they are toast) or do I just do it now.
Pacific.NW
Christian
Vancouver, Canada
I haven’t done anything yet, but will get the battery tested on my next visit to the dealership, and replace the 12V if necessary.
Assuming it's your battery...
If it's not too late for your battery, you could keep it on a maintainer when parked (overnight) to top it off. 86% is not a great place for an AGM lead-acid battery to sit for extended periods of time because then the sulfates could/will harden and become permanent on the plates.
The Lightning BMS does 2 bad things for AGM battery longevity:
1) lets it sit below 100% for too long resulting in sulfate coating the plates permanently; and
2) uses too high a charging current which can cause heat stress, venting and loss of electrolyte.
Both of those things will gradually damage the battery.
Sometimes the sulfate can be forced off with a "repair mode" with the battery out of the vehicle, but results vary.
So like others have said, get a new battery and keep it on a maintainer to "top it off" (to 100% with a slow low current charge) whenever it is not being used.
Lead-acid batteries prefer to be at 100% for longevity.
chuck27p
chuck27p
Chuck
Orange County, CA
You’re talking about a trickle charger every night? I’m probably too lazy to do that haha.
Ha!
But you can make it easy on yourself like I did without much effort.
I put an SAE plug next to my charge port in the truck, connected to the 12v battery.
Ford F-150 Lightning Alarm randomly went off 0-My Lightning-IIMG_6004-SAE at charge port
Inside the truck it is connected on the 6mm bolts with ring terminals and a 6mm nut, the negative downstream of the BMS sensor.
Ford F-150 Lightning Alarm randomly went off IMG_6024-battery BMS sensor
Inside my garage, next to my FCSP, I have a Noco Genius1 I can plug in to an outlet, and I ran an extension for the battery maintainer through an RV access panel I use for the FCSP cable.
Ford F-150 Lightning Alarm randomly went off IMG_6052-cro
In cold weather I plug the truck in to my EVSE anyway and I have the battery maintainer wire right next to it so doesn't take much time or effort.
Ford F-150 Lightning Alarm randomly went off IMG_6049-50 merg
It takes me less than a minute to connect the SAE plug to the extension and then plug in the NOCO Genius1.
I figure having to replace the battery, or getting stranded somewhere and needing roadside assistance or a jump would be a lot less convenient and use up more time and maybe money too, if not still covered under the warranty.
It's an ounce of prevention, that I believe will pay off in the long run.
My 2012 Nissan Leaf AGM 12v has lasted 13 years, kept on a maintainer when not being used.
