Jiji
- First Name
- Rick
- Aug 5, 2024
- Finger Lakes, NY
- 2024 F-150 Lightning
YesSo, this app is for apple only?
Can I use an OBD splitter. Use two doogls and use PANKUZU and ABRP?As far as I know, ABRP is the only app that can pull data from OBDII connector that isn’t a traditional scan tool app (OBDLink, Car Scanner, etc). Since only one app at a time can connect to the MX+, you have to pick the one that meets your needs.
Are you sure about that? I think is says ‘Bubbas Li…’Good results with the update. Took a spin around the block. Vehicle shows Lightning lariat.
I go with no as two devices would be talking on the single CAN bus and seeing responses they didn’t send.Can I use an OBD splitter. Use two doogls and use PANKUZU and ABRP?
I’m sure this will come back and haunt you.I can report it is working perfectly now with the latest Testflight build with my MY23 Lariat. Thanks Rick!
I will test using two doogls and see the results. I use ABRP for charging stations.I go with no as two devices would be talking on the single CAN bus and seeing responses they didn’t send.
Not a guess-o-meter, trapizodial rule numerical integration of the HVB current and voltage measurements.Battery At 66° start & finish shows EtE ties with guess meter.
I like what I see there.Here is the graph. I am very impressed with the level of detail in this app.
And there so many possibilitie, for example take the weather conditions (tap to drill down) and the course data (contained in the ) and plot the headwinds and tailwinds along the route.
