Mcfly
Billy
Socal
23 Pro SR
Realtor
Finally got around to installing these this weekend. I couldn't find anyone who had mounted a set, so it was a roll of the dice. These are for the ice trucks. In my research there are no flares available in the us market for the lightning. These are the sport flares by Rough Country, available paint matched for most F150 colors or in flat black for half the price. As for the fit, in the front, they are slightly too short. It would look better if they came all the way to the front bumper. In the rear, there's a one inch gap between the bottom of the flare and the bottom of the bed. I might try to come up with something to fill it. Also some of the mounting holes don't line up exactly. The charge door clears with no issues. All in all I'm happy with the look. My wheels have a good amount of poke,+18 offset, and the tires are 34's.
Edit: @MUSTANGMICHAEL mentioned these will potentially leave marks in the paint where the rubber seal meets the fender. Dirt can get in there and scratch thru the clear coat. Recommended adding ppf to the area before install.
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082719495
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082724944
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082733765
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082755364
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082749580
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082818907
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082822492
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082834862
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082844089
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082830282
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082630704
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082936190
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082644397
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082656449
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082805650
Ford F-150 Lightning Sport Fender Flares by Rough Country installed IMG_20260223_082800626
Ned B
Ned
Harrisonburg, VA
2023 XLT
Professional Driver
Those look great! I'll be following to see how you fill the gap on the fronts. Nice color on your truck too btw!
beyondthelens
So Cal
Lightning Flash
This is a nice touch. I almost attempted this as well but w/ the flat black for more of an "E-Raptor" look. How much modification/drilling did you need to do for the rear set since the holes didn't line up? How long did it take you?
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Took around 2 hrs for the install. I had to drill 2 holes on each side for the rears, inner lip of the fender.
Frode Vike
Frode
Norway
2024 Ford F-150 Lightning Platinum, 1969 Ford Mustang, 1989 Mercedes-Benz 300SE
I also have a set of those that I haven't gotten around to install. They do require some massaging/work in the rear, as I have power running boards. Do you think these would be possible to run with the mud flaps?
Ford F-150 Lightning Sport Fender Flares by Rough Country installed 55021414331_7b5984e7de_k
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Possibly, you have to remove the black plastic trim piece on the lower front side of the rear wheel well. On the rear part of the wheel well I used the lower inner most hole, removed the push tab, pushed the flare in and up and pushed the tab back in. You don't remove the plastic trim piece in the rear. Can you post a picture of the mud flap from the inside of the wheel well?
Freemarket
Michael
Lightning, Cybertruck, Model S, X. Ford Raptor
Finally got around to installing these this weekend. I couldn't find anyone who had mounted a set, so it was a roll of the dice. These for the ice trucks. In my research there are no flares available in the us market for the lightning. These are the sport flares by Rough Country, available paint matched for most F150 colors or in flat black for half the price. As for the fit, in the front, they are slightly too short. It would look better if they came all the way to the front bumper. In the rear, there's a one inch gap between the bottom of the flare and the bottom of the bed. I might try to come up with something to fill it. Also some of the mounting holes don't line up exactly. The charge door clears with no issues. All in all I'm happy with the look. My wheels have a good amount of poke,+18 offset, and the tires are 34's.
You Tremor’d it, very tasteful all around šŸ‘šŸ¼
I’ve wanted more of the Raptor look, I might try this on mine. I don’t think the front gap would bother too much.
nate002
nate
ā€˜24 Flash | Antimatter Blue | 9.6kW Pro Power
Awesome, looks great! Thank you for posting this. I have a flat black set just sitting in my garage waiting to be put on.
MUSTANGMICHAEL
Michael
Wisconsin
23 f150 Lightning XLT
Looks good and I’ve had the same ones on a 5.0 F150. It’s worth mentioning that they will destroy your paint! Where the rubber strip is on the plastic flare, dirt and grime gets caught under and the vibrations from the road will cause the flares to move ever so slightly. Then the dirt and grime etched through the clear coat, then the paint. It’s a common. Issue with them. I’m only mentioning it because I was not aware of it and I was rather frustrated when I went to trade it in and the dealer mentioned this issue and asked me to remove them to check the paint.
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Thanks! The e raptor look would be sick.
Mcfly
Mcfly
Billy
Socal
23 Pro SR
Realtor
Good to know! I'll remove them and put some ppf where they touch and re install.
Just did some googling and most fender flares have this issue, even ones that come stock. Just saw a video, a guy removed factory flares from a tundra and they had nearly eaten thru the metal!
nate002
nate
Oh wow, that’s crazy! Wonder if PPF would even work then?!
MUSTANGMICHAEL
Michael
Wisconsin
Yea. I’ve seen so much damage caused by them after I had it happen.
