Bigger front battery?
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
Stock tray will fit H4 with minor trimming. I have a thread on this and highly recommend it.
H5 or H6 would require more extensive modifications since the original tray will not accommodate. You would have to fabricate a new tray that sits on top of the existing tray to give you the width and you'd have to test fit to make sure the cables are long enough for the raised tray and additional width of the H5/H6. Its probably possible however, more work.
I just found a video for a Maverick Hybrid. It's got an H5 and some have put an H6 in there. It's under the rear seat so not applicable to our situation, but the room behind that plastic hatch in our frunk is plentiful. It's just the left to right (width, but normally called the length) that's different. Other two dimensions are the same as an H4. But I think the H4 would be good enough for my situation.
jwrezz
Teacher/Firefighter
jwrezz
Teacher/Firefighter
My H4 install went well. My tray (2024 Lariat) is different so cutting was different as well. Attached pics.
Ford F-150 Lightning Bigger front battery? 1552
Ford F-150 Lightning Bigger front battery? 1556
Ford F-150 Lightning Bigger front battery? 1557
Ford F-150 Lightning Bigger front battery? 1558
Ford F-150 Lightning Bigger front battery? 1559
Ford F-150 Lightning Bigger front battery? 1560
Ford F-150 Lightning Bigger front battery? 1561
