What is this?
jwrezz
1996 Ford ExplorerXLT, 2006 Subaru OBS LLBean, 2024 Ford F150 Lightning Lariat
Teacher/Firefighter
jwrezz
Teacher/Firefighter
jwrezz
Teacher/Firefighter
Well, if the googly eyes fall off, no big deal. But if you are in a state with a mandatory front license plate then having the tape fail and losing the plate is a big deal.
Sorry, I wasn't clear. It's the 3M VHB. "That ain't goin no where!" LOL
Efiddy
Micahel
Bethesda, MD
2025 F-150 Lightning Flash
Has anyone found a permanent solution for mounting the front plate. I had my front plate removed. I’m not going to say stolen because that bracket never felt “robust.” I’m not opposed to drilling. A tow hook mount is removable. Maybe tape is an option but for the same OEM bracket that rattles down the road?
Athrun88
Toronto, Ontario, Canada
Anything attached to the vehicle is removeable, just depends on the amount of effort required to remove it. Aside from chemically welding the plate to your bumper, the OEM mounting bracket with Torx screws might be your best option. Not every plate theif has Torx bits on them and might be just enough to leave your plate alone.
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
I have a front license plate frame which came with the car but the dealer did not install. It sits between the lower edge of the frunk lid and the bumper. It does not interfere with any workings of the truck. It is attached with two screws, and the plastic of the bumper has two indentations where you need to drill. It was easy for me to install myself, and if you wanted to remove it then the screw holes would only be visible with the frunk open, and only if you look very carefully.
Ford F-150 Lightning What is this? IMG_0433
Ford F-150 Lightning What is this? IMG_0434
