Lightning Front Headlight Swap
nbeasy
Nick
2024 F150 Lightning Platinum
Hey everyone — doing research on what's actually possible for swapping out the stock headlights on a 2024 Lightning Platinum. I'm not a fan of the milky white "7" shaped DRL housing and have already tinted it to get a more blacked out look, but really want to explore replacing the housing entirely.
From research I've done so far:
The 21-23 ICE F-150 projector housings appear to physically fit the Lightning fascia aperture since they share the same NL3Z housing family. The blocker is the LDCM — the Lighting Driver Control Module that sits on the back of each housing and drives everything including the bending motor, DRL, and on the Platinum, the matrix pixel array for glare-free high beams. The LDCM is confirmed to be a discrete bolt-on module that transfers between housings, but nobody has documented whether a Lightning LDCM physically mounts to a gas F-150 Platinum projector housing or whether the internal connectors match.
I also looked at the Diode Dynamics Elite Max DD5167 — fits physically but has its own standalone MCU with no CAN or LIN connection to the vehicle, so dropping the LDCM into that housing would likely generate persistent DTCs since the LDCM would find the wrong electrical loads on its output wires.
The most promising path I can see is using a used gas F-150 Platinum projector housing (ML3Z-13008-AL/AK) as a donor — it already has a bending motor and projector LED array, just without the milky "7" DRL diffuser. The specific questions I'm trying to answer:
Has anyone physically compared the LDCM mounting interface between a Lightning Platinum housing and a gas F-150 Platinum projector housing? Same bolt pattern? Same internal connector?
Is the matrix pixel array inside the Lightning housing a discrete removable component, or is it integrated into the housing structure? Could it transfer to a different housing?
Has any Lightning owner attempted any headlight swap at all, even OEM to OEM across trims?
Any input appreciated — seems like this is genuinely uncharted territory for the Lightning specifically.
A slight correction. All Lightnings have glare free, not just Platinum. So your question is applicable to all owners.
nbeasy
nbeasy
Nick
Ah yes thanks. Edited. I'm looking at part numbers and looks like all Lightnings have the same headlight part numbers, and actually the same LDCM part #s:
NL7Z-13C788-F -- the LDCM, one per headlight
Seems like the only difference between Pro, XLT, Lariat, and Platinum is all just whats enabled in software.
RLXXI
3rd rock
Automotive Technician
The connectors are completely different between a smoker 150 and the Lightning. At least they are for the 25 year models.
1st pic is a regular f150, 2nd is the lightning. Close but no cigar.
Ford F-150 Lightning Lightning Front Headlight Swap 2025regf150headlightconn
Ford F-150 Lightning Lightning Front Headlight Swap 2025lightningf150headlightconn
The shape of the opening in the fender is completely different on 21+ F150s than it is on the Lightning. The Lightning is much closer to pre-21 F150s, but not exactly the same either.
Mcfly
Billy
Socal
23 Pro SR
Realtor
Beat me to it, the Lightnings head light and tail light shape follows the previous gen Ice trucks. This was one of the things I hoped would change to match the current ice trucks if Ford did a mid model refresh on the lightning.
RLXXI
3rd rock
I have a feeling this is going to be a tough mod. But I’ve been surprised before on this forum so who knows.
They may physically fit the truck but it's going to take some dicing and splicing of the factory harness and they may still not work due to differences in electronics if any.
