Glare Free Headlights enabled with Forscan, but no difference?
Ncasini
Nick
SouthWestern PA
2025 Lightning Flash
I used Forscan to enable Glare free but don't see any changes Do I have to reset modules? I verified the changes were accurate. (2025 Flash)
Does your headlight symbol on your instrument cluster look like this? Are you going at least 30 to 35 mph when you are testing them?
Ford F-150 Lightning Glare Free Headlights enabled with Forscan, but no difference? {filename}
What is your Forscan experience? Pro or newbie? It sounds like you missed a setting or two. You can try to a module reboot on the APIM and maybe the others. Also look to see what DTCs you have. Particularly with HCM.
I show how to reboot a module here.
brirr76
Midwest / KC
2024 F150 Flash / 9.6kw + Max Tow - Midwest / KC
I just did this for my 24 Flash two days ago. I did all the right things and did the soft reset along with turning on and off the truck but the menu did not show glare free option UNTIL I simply turned my light switch from auto to off and back to auto and.... It worked! Its really nice so far. Hope this helps someone else having trouble.
Good point.
I should have added that some folks have had to go through several restarts or maybe the modules sleeping before the functionality appeared. Rebooting should accomplish the same thing I would think.
HornetRaider
Abe
DFW
2023 Lariat ER
I had the green icon and didn’t notice a difference. Resetting APIM module did the trick. You should absolutely notice it. I was underwhelmed before realizing I didn’t have them properly enabled. Just adding my experience since I had the green headlight icon and still didn’t have them enabled.
