Putco LED Logo Install Re - Engineered No Fusebox!
Cbowe
Christopher
Hayward CA
2022 Ford Lightning
Senior Manager
A video 1 year and 2,000 miles in the making! ⚡
MartinRebuilds made the journey from Kansas to California as we re-engineered the Putco Light Up Ford Emblem install for the Ford Lightning!
No pinched wires, notching, drilling, or fuse box taps—just clean OEM headlight power.
Don’t miss this awesome collaboration! 👇
Maineiac12
Iowa
I’m surprised Ford bought back your truck if the issues were caused by a 3rd party part. Was it dealer installed?
Cbowe
Cbowe
Christopher
Hayward CA
2022 Ford Lightning
Senior Manager
In fairness, I’m not sure it was the Putco install but it was a concern of Ford’s and they removed the Lightning as a supported truck for it on the Ford website after my problems but I also had the rear light bar and the entire 12v harness replaced (twice) and a HV battery module replaced and even after disconnecting the Putco LED and 3 12v batteries later still had problems 😂 but yes when the dealer installed the Putco LED in to the fuse box they notched it and water got in they eventually replaced it but that may have started the cascade of other things. Or it may be totally unrelated and a coincidence but this way you avoid ever having to deal with any issues or possibilities or questions about it!
Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
should i remove my current fuse box setup and install this harness? I havent had any errors or water in my fuse box. i pressure my truck regularly and it lives outside. it would have happened by now.
WildBlue
Somewhere
2024 F150 Lightning Flash
I watched the video. I have the Putco lighted emblem (fuse box design) and am now convinced to go the harness route. Problem is, I am not sure how to get that harness that was demonstrated in the video. Does Putco offer it and I have to modify it per Martin Rebuilds advice?
Cbowe
Cbowe
Christopher
Hayward CA
2022 Ford Lightning
Senior Manager
if it has been doing fine it will probably keep doing fine. I’m curious how did you route the wire in to the fuse box?
Aminorjourney
Nikki
Internet
www.transportevolved.com
2023 F150 Lightning Lariat, 2017 Chevrolet Bolt EV, 2006 Vectrix VX-1
Looks like the one we did last year :) It's a nice install - I modified my stock harness for the light off Martin's advice :)
Glad you got yours done.
Cbowe
Cbowe
Christopher
Hayward CA
2022 Ford Lightning
Senior Manager
Your video was awesome I didn’t do the washer mod like you did. I do miss that from my 22 and of course I also lack the awesome rooster 🐓😆
Storm Breaker
Norm
truck driver
i just notched it under the lid and ran it through that.
Rwidman
Robert
Ford F150 Lightning, Ford F150 Limited
This is a great video. I installed my Putco light a while back before the harness modification. One issue I have is the interference with the FM radio. Has there been a better fix for this? I am using the Ferrite Ring Core Noise Suppressor Clips but they are not working very well.
CdnCGM23
Barrie, ON Canada
Military
Chris, does or will Martin's make and sell the harness to do this? Or Putco sell the harness?
Cbowe
Cbowe
Christopher
Hayward CA
2022 Ford Lightning
Senior Manager
The harness comes from Putco but is for the gas F150 and is too short and 2 pins are swapped so in Martins video (which is linked at the end of mine and in the description of mine) he shows how he made the extension we used and which wires to take power from. He doesn’t sell the harness himself though
WildBlue
Somewhere
I haven't watched that Martin Rebuilds video yet, but does he link a Putco part number for the harness he modified?
