astricklin
Plug in a blender and get fraptor frappesI want to see a F150 Lightning with a Fraptor grille.. ???
Mr. Plow, that's my name.
That name again is Mr. Plow.
Solar PV Tonneau panel on the bed for when the solar powered camper is not there.
The Worksport website (worksport.com) doesn’t appear to be working today - which isn’t confidence-inspiring - but here’s a review:I'm very curious about a solar bed cover. Do they already exist and can the be used to charge your Lightning?
If my truck is sitting all day at work or all week at an airport it would be nice to add a little free juice to the battery.
do you have a link?
You're not going to get enough range for it to matter.I'm very curious about a solar bed cover. Do they already exist and can the be used to charge your Lightning?
do you have a link?
So no 2nd Gen ICE Lightning decals, then?Swapping out the lightning decals with the 2nd Gen ICE lightning decal. Also adding a Carolina Squat lift kit.
Only kidding about one of those.
I'm thinking of going this same route, I might also investigate if the Lightbar across the front can be purchased as an OEM part, or aftermarket, and added after the fact.I’m getting a Pro, painting the bumpers, door handles and mirror caps. Then adding power running boards as soon as I can confirm they will fit.
I have seen this before. If it is affordable, I would definitely be interested. However, I don't understand why it needs the roll bar thing up against the cab. I would want it flat like a normal cover. Any guesses why this roll bar is necessary?The Worksport website (worksport.com) doesn’t appear to be working today - which isn’t confidence-inspiring - but here’s a review:
https://insideevs.com/news/441787/worksport-introduces-terravis-solar-truck-tonneau-cover/
Actually, for my use case, this might make sense. I read that the solar bed cover will cover 30% of the usual driving range, which is about 40 miles. 40 miles x 30% = 12 miles. My normal daily driving is 8 - 10 miles (I live very close to work and I have the worst use case for ICE...I have to drive very aggressively just trying to get the engine temperature up).You're not going to get enough range for it to matter.
If, and that's a big if, you are actually getting a full 1kw out of the panels as stated on the website for the above product, then ya you'll probably get about 15-16 miles of range in 8 hours, and that's if you're parked in full sun the whole time. Any part of the panels being shaded will greatly reduce the output.Actually, for my use case, this might make sense. I read that the solar bed cover will cover 30% of the usual driving range, which is about 40 miles. 40 miles x 30% = 12 miles. My normal daily driving is 8 - 10 miles (I live very close to work and I have the worst use case for ICE...I have to drive very aggressively just trying to get the engine temperature up).
My guess is it supports the segments when they are folded up so you can use the full bed, granted it will be blocking the back window.I have seen this before. If it is affordable, I would definitely be interested. However, I don't understand why it needs the roll bar thing up against the cab. I would want it flat like a normal cover. Any guesses why this roll bar is necessary?
I'm also not an expert on solar panels, but I live in South Texas...and my lab where I park daily is in the middle of a solar field...and we also test solar panels/storage batteries for solar fields at the Energy Storage Technology Center (after viewing the data from the portion we control, I kind of have an idea on what is possible at this particle location)...and I guess you glossed over the part where I say I drive 8-10 miles per day...but go ahead and crap on anyone who might think this might be viable telling them why it won'tIf, and that's a big if, you are actually getting a full 1kw out of the panels as stated on the website for the above product, then ya you'll probably get about 15-16 miles of range in 8 hours, and that's if you're parked in full sun the whole time. Any part of the panels being shaded will greatly reduce the output.
I'm not an expert on solar panels but from what I see available, there's no way you are getting 1000 watts out of anything the side of the truck bed. From what I can see, you'll probably be able to get 500 watts max out of the entire surface area of the bed
