Missing Bolts...SMH!
Legacy23
KJ
'23 Lightning Platinum
IT Manager
I'll keep this short and sweet. I rotated my tires today and realized I'm missing the 2 bolts that attach the shock to the lower control arm in the front. Pictures below...
Does anyone know the part number so I can replace them?
Thanks!
Ford F-150 Lightning Missing Bolts...SMH! IMG-20250328-WA0006~2
Ford F-150 Lightning Missing Bolts...SMH! IMG-20250328-WA0007
Ford F-150 Lightning Missing Bolts...SMH! IMG-20250328-WA0008
Ford F-150 Lightning Missing Bolts...SMH! IMG-20250328-WA0009
Maineiac12
Iowa
Why not have the dealer do it? It’s a warranty issue.
Literider150
Brad
67 Deer Trail
2024 F150 Lightning
I just completed a safety recall for the upper control arm where the nut could come loose. Mine is a Dec. '23 build but a 2024 model. Fell into the recall time frame.
Yeah, your's sounds like whoever modified it didn't do a very good job. Did you notice it in the ride?
Scorpio3d
SS/IBA car wash owner
Thanks!
I don’t know the part number but you can check on parts.ford.com
Legacy23
KJ
IT Manager
I've put 3k miles on it in just over a month. Haven't noticed a thing.
electricpig
Tim
Northwest Arkansas
F150 Lightning, Tesla Y
JIC you aren't aware, there will be torque specifications for those bolts. Too much is just as bad as too little. Got to get it JUST RIGHT. Hence the recent recall for bolts.not torqued correctly for a nut on upper control arm.
Legacy23
KJ
IT Manager
I am aware, thank you for the reminder though. I'll give it just the right amount of uggas...lol
NW Ontario Ford Lightning
Robert
NW Ontario Canada
2024 F-150 Lightning XLT
Contractor
HEY !
Those are technically called "Ugga-Dugga's"
A "Ugga Dugga" which is defined as a unit of measurement, often used in automotive workshops, representing a combination of time and torque, roughly equivalent to 14-16 foot-pounds of torque per Ugha-Dugha. These units can vary by region.
:crackup:
Joe Dablock
Joseph
Stewartstown Pa. 17363
I would just go to my 5 gallon bucket of automotive bolts, find the largest bolts in bucket that will fit the holes, find nuts. Install it. As tight as you can tighten it with a half inch ratchet will be good enough. This is not rocket science.
MaintGrl
Marsha
El Sobrante, Ca
Hence the "Ugga-Dugga's"
roddiaz1
Rod
Pittsburgh
At the very least, do this for now, until you get the parts you are looking for.
my two cents.
